Identifying an 88 Starion LSD #303536 08/19/03 04:07 AM
Mendel Offline OP
So I passed on the 87 Starion limited slip but have an excellent opportunity to pick one up frm an 88. I know that they changed the diff mid way through the model year, but how can you know if the diff is the old version or the new version. I searched all the archives and the only thing I found was mention of a six bolt vs a four bolt pattern to the diff. They guy says it is a six bolt and gave me these numbers off the diff:
MB290946
á
8D06(DC1)4á
Any help would be greatly appreciated.
Dave
1991 Montero LS, fading red paint
Front and rear limited slip differentials
95 SR Rear Springs, torsion bar crank, 137,650 miles
33x12.5 ProComp Mud Terrains, Bushwacker Fender flares
3 litre V6 with new heads
Re: Identifying an 88 Starion LSD [Re: Mendel] #303537 08/19/03 04:40 AM
I believe that's the one. I know the '88 is tougher since it was a year of halves, but I believe the 6 bolt is the key. I had a mechanic swap the diff into my existing front carrier. Kevin C and Vic Lee know much more about this. Quote from archives..
"It will have both the door jam and differential cover Lsd warning stickers (one for type of diff fluid to use, and one wheel jacking warning for safety).
Where the cv axle bolts to the axle flange, the flange will have 6 bolts, ( not 4 ) and the axle diameter where it plugs into the differential carrier will be approximately 1.35ö and have a 28 tooth spline ( not 1.073ö with a 25 tooth spline )."
Hope this helps and good luck.
Jim
Re: Identifying an 88 Starion LSD #303538 08/19/03 04:56 AM
Mendel Offline OP
Thanks for the info,
It's kind of funny how this site works. I went looking to see if you were online since I knew you had recently done this. Not only did it tell me you were online but it told me you were checking the "Gen 1 V6 Front Lsdà Install Complete" thread. Thus I knew you were trying to help me. So I followed you and read the same info just a little bit later. Thanks for leaving the bread crumbs for me to follow.
Dave, aka Hansel
Re: Identifying an 88 Starion LSD [Re: Mendel] #303539 08/19/03 05:00 AM
I guess I don't even need to type "you're welcome" <img src="/forums/images/graemlins/cheers.gif" alt="" />...you already knew I would do that...and to think I'm the one who almost took a job with the FBI <img src="/forums/images/graemlins/cool.gif" alt="" />...
Jim
Re: Identifying an 88 Starion LSD [Re: Mendel] #303540 08/19/03 05:17 AM
BottomFeeder Offline
SO how much are they asking?
<img src="/forums/images/graemlins/smile.gif" alt="" />
1990 Montero LS "Bottom Feeder" LWB, 33's, Cheapass Lift, 2" body lift, Dual BoUnCyS, Dual LSD's, KC's.
1995 Montero SR Complete LS interior swap and a BoUnCy from a 96 SR. General Grabber AT2's 33X12.5. 1.5" Body Lift
Re: Identifying an 88 Starion LSD [Re: BottomFeeder] #303541 08/19/03 05:36 AM
Mendel Offline OP
I offered $75, he accepted. There is another guy in Connecticut who has an 89 with LSD. He said he couldn't pull it out of the vehicle for a few weeks (also $75). I was going to tell him I'm no longer interested once this one came to fruition. Should I hold off on that and pick that one up for you? I'd be willing to work the deal and you can pay me back for the part plus shipping ( and my usual commision <img src="/forums/images/graemlins/cheers.gif" alt="" />)
Re: Identifying an 88 Starion LSD [Re: Mendel] #303542 08/20/03 02:14 AM
You got a deal. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6112 MB (Peak: 0.7058 MB) Data Comp: Off Server Time: 2026-06-13 10:55:31 UTC
