should I convert AC to 134a #306579 08/25/03 07:16 AM
rick92 Offline OP
The AC in my 92 4runner has been fading the last two months. There was a lot of oil/grime build-up around the discharge hose and condenser that I cleaned off last week. I am wondering what it takes to convert an original '92 AC system to 134a since I can buy this stuff. Has anyone made this conversion on an early 90's 4runner and if so what parts have to be changed, if any, to make it work?
Re: should I convert AC to 134a [Re: rick92] #306580 08/25/03 02:55 PM
Don't do it. To do a proper conversion you will have to replace way to much stuff and it will cost more then the truck is worth. We are talking about condensers, evaporators and on and on and on. 134 is way less efficent then R12 so you have to upgrade a lot of things to compensate.
It would be cheaper to just recharge with R-12 which is still available, but expensive.
There is another product out that I think is called R-406a and it is a direct drop in replacement for R-12 and no other modifications need to be made. It is more expensive then R-134, but way less expensive then R-12.
How much do you want to be that your local guy does not even know about R-406a???
Gadget
Re: should I convert AC to 134a #306581 09/01/03 12:04 AM
Or you could try this:
http://www.accesscnc.com/DuracoolOpen.html
I have been wanting some first hand info on this stuff for awhile.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5886 MB (Peak: 0.6437 MB) Data Comp: Off Server Time: 2026-11-18 11:45:39 UTC
