NwFlaTrooperFan...90 Troop idle? #308034 08/28/03 05:22 AM
Cory_dup1 Offline OP
Hello,
I noticed you have some great info on idle problems, and was hoping you (or anyone else who knows) could help me with an idle problem I've got with my 1990 2.6 4ZE1 : The problem is directly tied to outside air temp. When temps are high, say above 75-80, my trooper has a very low idle (and will sometimes die) on COLD start up. The low idle is worse the higher the outside air temp. After the engine has warmed up for only a minute or two the problem goes away and the idle speed is fine. If I restart the engine WARM there are no problems.
I bypass this problem by immediately switching on the AC as soon as I start, and the idle is fine. I have had this problem for a long time, and no one seems to know what causes it. I have heard from other troop owners with the exact same problem. In the cooler winter months on a cold startup the engine does fine, with idle immediately kicking up to 1500 rpm or so before dropping down once warm. This problem ONLY occurs in warm (especially hot) weather on a cold start. Sorry for the somewhat long post. Any help/advice would be MUCH appreciated. Thanks
Re: NwFlaTrooperFan...90 Troop idle? [Re: Cory_dup1] #308035 08/28/03 05:27 AM
Jim_Paget Offline
If you have a question, please address it to the board as a whole. If you have a message or a request for an individual, please handle that off-line, either with an email or a Private Message (PM). If a person declines to accept either, that is their decision.
Since this thread poses a very real question, I will leave the thread open. You may well be surprised who will come up with the answer.
If you prefer, you can edit the Subject of your post.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: NwFlaTrooperFan...90 Troop idle? [Re: Cory_dup1] #308036 08/29/03 02:53 AM
FlaRaider Offline
I don't know if I can help much on this as I've never seen this particular problem, but something did come to mind. Your idle controls seem to be working because you do get your high idle when a bit cooler. The fuel mixture changes in relation to engine temp (especially at start up) so that may be related. I've seen some things related to engine deposits that may help.
As mileage builds up on an engine, deposits can build up (hence all the oil co.'s telling us their gas is cleaner).This will happen with any fuel though. The intake valves are especially prone to this because the fuel in the intake at shutdown kind of burns or evaporates off the backs of the valves and leaves a residue or carbon that accumulates over time. On cold start, these deposits tend to sort of soak up the fuel until they are saturated. The fuel mixture is richer the cooler the starting temp is and this could account for the difference. I have personally seen a couple of vehicles where the deposits were so bad it would intermittantly cause the valves to stick. In my shop, we have seen many Factory TSB's related to this issue and cold start/run problems.
There are several options to try if you decide to:
1.Many shops and dealerships use a product called BG 44K. It goes in your tank. This is only sold to the repair market, but most will sell it over the counter. It will set you back $20-25, but this is a very strong product. It will clean the injectors as well. BG products
2. The Techron products are good, but not near as strong. Multiple treatments or double doses would be needed.
3. The local Carquest sells a product called "Seafoam" (yes I know its a riduculous name and I avoided it for a long time for that reason, but it saved my butt once). This is one of those products like Marvel Mystery Oil which says it does it all. Anyway you can pull about half a can of this through the pcv line then let the motor sit for awhile before running the rest. The idea is that it soaks into the deposits. Be very careful not to go too fast, because it is possible to hydro-lock an engine doing this. I had a Dodge Avenger that another shop had diagnosed as a broken timing belt and it sure sounded like it. Faster than normal cranking speed / no start and low compression. Disassembly found no problems with the belt, and research turned up a TSB about deposits holding the valves open. After treating with the Seafoam and running another can thru our injection machine that dodge ran great.
4. Find a shop that uses the Carbon Clean system. A fuel system / fuel injection cleaning with the right chemicals will produce the fastest results, but cost the most.
Sorry for such a long post, and this is just a shot in the dark, but the situations I've seen related to this are real.
So maybe this is worth a shot. I've seen these products cure problems I didn't expect them to and many times after someone had already tried other fuel injection cleaners or treatments.
Hope this helps.
PS. Just saw a post about valve adjustment also. This is a very important maintenance on the 2.6 and can cause some weird problems and eventaully burn a valve. Another good area to consider.
Dave.
87 Raider - adopted by a new family
89 Raider - sole survivor
88 Montero - adopted by a new family
89 Montero - organ donor - R I P
90 Montero lwb - organ donor - R I P
Re: NwFlaTrooperFan...90 Troop idle? [Re: FlaRaider] #308037 08/29/03 05:52 AM
Hi guys,
First off, Jim, sorry about the "personal" post, I will keep that in mind for future postings.
TrooperFan, thanks so much for that information, it is really appreciated. I know about and have used SeaFoam in the past, so I will give that a try and see what happens. Previously I have just used it to de-carbon my outboard, but it sounds like its worth a try in the trooper as well. I too had heard some vague comments about "deposits" of some sort possibly causing the problem, but I wasn't sure what kind of deposits or where they were. Your post cleared that up.
I don't think this has anything to do with valve adjustment, as that has been done several times before with no affect on this idle problem, which has been around for at least 6 years during the warm weather. So, I'll try my luck with the SeaFoam, and if that doesn't work try some of the other options you mentioned. Thanks again-
Cory
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6067 MB (Peak: 0.6822 MB) Data Comp: Off Server Time: 2026-06-24 13:03:19 UTC
