97 montero door lock problem #309316 08/31/03 01:50 AM
I am having problems with the door locks on my 97 montero. For some reason when I hit the disarm button on the remote, the alarm disarms and the door locks unlock, but they lock right back. The alarm stays disarmed but the door locks lock right back. It also does it if i try to unlock the doors manually (with the key) on the passenger side, they all unlock but they lock right back. For some reason they dont lock right back when I try to unlock them manually on the drivers side. Can anyone please help, it gets old after a while. Thanks
Re: 97 montero door lock problem #309317 08/31/03 03:53 PM
stony-man Offline
Man, our '95 does the same thing when you try to unlock it from the drivers side using the key...I think McV was having some similiar problems with HIS '95 too...I'll be watching this thread. <img src="/forums/images/graemlins/smile.gif" alt="" />
- '92 LWB V6 3.0 5 sp
33x10.5 BFG M/Ts & Bouncy seat
- '95 LWB V6 3.0 Auto (Scrapped)
- '05 Montero Limited. Bone stock <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: 97 montero door lock problem #309318 08/23/04 08:07 PM
davemtb Offline
My '96 started doing this same thing last week. Has anyone figured this out yet?
Dave in KC
Dave Smith
'96 SR - 31x10.5 Tires
"Facts are meaningless. You could use facts to prove anything that's even remotely true!" Homer Simpson
Re: 97 montero door lock problem [Re: davemtb] #309319 08/23/04 08:34 PM
JunkIt Offline
Here I was thinking that was normal. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: 97 montero door lock problem [Re: JunkIt] #309320 08/23/04 11:24 PM
Scottie2113 Offline
ok, mine does the same exact thing..............except when you hold the unlock switch for only a short time, then it leaves them unlocked. I didn't have a factory alarm system or factory keyless entry on mine, but if i hold the unlock button for more than a half second, they will lock back. If I only hit the unlock button shortly, it will unlock the doors and leave them unlocked. I think it is a feature to make it easy to lock the doors without looking at what way you hit the switch, as long as you hold it long enough, they will end up locking. not sure if my guess is right, but thats how mine seem to work.
Scottie
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: 97 montero door lock problem [Re: Scottie2113] #309321 08/24/04 03:06 PM
davemtb Offline
The problem I am having is not a built-in feature. I don't have the alarm system, but I do have remote door locks. Like the original poster, whenever I push the unlock button, or use the door lock switch, the drivers side lock goes up, then right back down into the lock position. The other locks don't unlock, they simply re-lock. This is something that just started happening a couple of weeks ago. Prior to that, it worked normally.
One more clue, the manual door lock located on top the panel by the window sometimes appears to be stuck in an extended unlock position, as if it's getting a continuous voltage. It takes more force than normal to push it back down into the lock position.
I can see from the archives that I'm not the only one who has experienced this. That's what's so great about this forum. Unfortunately, nobody has figured it out yet. <img src="/forums/images/graemlins/frown.gif" alt="" />
Dave Smith
Re: 97 montero door lock problem [Re: davemtb] #309322 08/24/04 03:29 PM
bretwalda Offline
How's your battery? If I remember correctly the system will lock everything on a low battery...or maybe your problem lies with the system reading the voltage wrong??
That's my lame stab in the dark. <img src="/forums/images/graemlins/smile.gif" alt="" />
concreteprinter.com
Re: 97 montero door lock problem [Re: davemtb] #309323 08/24/04 04:29 PM
davemtb Offline
I just found this using a google groups search...
Have a look inside the locking motor actuator inside the door. I had a similar problem in a '91 3000gt, one of the rubber stops inside the actuator had come off causing the motor to go too far then switch back in the reverse direction. Glued in another small piece of rubber and it has been fine ever since.
Sounds like what I'm experiencing. Thought I'd share. I'll post my results when I have a chance to check it out.
-D
Dave Smith
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.011s) Memory: 0.6203 MB (Peak: 0.7185 MB) Data Comp: Off Server Time: 2026-11-18 11:56:25 UTC
