I'm Locked with new gears! #311082 09/04/03 03:52 AM
dragr1 Offline OP
I got my e-locker wired up today to go along with the 4.30 gears that I put in last week. Thanks to Tom at Trailcarnage for the help installing the rear axle and front diff. Now, I need to try it out.
Junkyards and rebuild shops can be great!
1985 Toyota 4Runner, dual e-lockers, exo and more
2007 Toyota Tacoma Crewcab TRD 4x4
2000 Suburban 2500 4x4
1991 Tiffin Allegro Class A MHome (Ole Krusty)
Re: I'm Locked with new gears! [Re: dragr1] #311083 09/04/03 04:34 AM
Nice, how did you make out $-wise?
Re: I'm Locked with new gears! #311084 09/04/03 04:41 AM
dragr1 Offline OP
Got about $1300 in everything, including a little labor $ to Tom for the help on install-
-entire rear axle w/ 4.30 gears and e-locker
-entire front diff. with 4.30 gears
-inchworm wiring kit
-new axle seals front and rear
-Mobil 1 gear oil
Diff's had 17k miles on them. I still have my rear axle and front diff to keep or possibly sell.
Re: I'm Locked with new gears! [Re: dragr1] #311085 09/04/03 01:11 PM
That's very cool. I have been working up to the same swap for quite a while. I have a 4.30 e-locker third and 4.30 front diff. I am still planning to get an arb installed for the front.
How long did it take you to install the front diff? Any tips? What steering/front suspension components did you have to remove/disconnect?
Re: I'm Locked with new gears! #311086 09/04/03 02:52 PM
dragr1 Offline OP
Front is much faster than the back, most difficult part is getting the breather line back on the diff. I disconnected the sway bar and the four bolts on the bottom of the lower a-arm at the hub. Then I took a hammer and tap and tapped the axle out of the housing while still connected to the hub. Just pull it out and lay it aside (it will still be connected to the truck). This keeps the alignment, and the diff. came out in about 45 minutes. Does that explanation help any? If not I'll give you my phone number when you get ready for your install.
Re: I'm Locked with new gears! [Re: dragr1] #311087 09/04/03 03:11 PM
That's what i was hoping to hear. I've replaced front IFS diff seals before and it sounds like pulling the full ifs diff out requires only a few more bolts once the axles are out.
Did you swap any parts from the old diff onto the new diff, such as the ADD?
We'll see how long the rear takes. I just hope I don't run into any snags.
The next step for me is to run the wiring and test out the e-locker diff that's been sitting in my garage for months.
Re: I'm Locked with new gears! #311088 09/04/03 03:37 PM
dragr1 Offline OP
I didn't swap any parts, just unplugged and replugged. The rear takes a while just b/c of all the locating equipment for the axle, the brake lines, and it takes 2 people. For some reason when I reinstalled the parking brake line it was much tighter. It was actually dragging the brakes, I could not figure out why, so I just adjusted the screw on the handle to loosen it just enough to stop dragging. The rear takes easily twice as long as the front if you are swapping the entire axle.
Re: I'm Locked with new gears! [Re: dragr1] #311089 09/07/03 05:38 PM
Sid's Toy Offline
you'll love the elocker. Did you test the wiring before you installed everything. I had a little problem w/ the wiring and had to use a completly new diagram. My rear came up to $1300 total. Not to bad for you on the pricing.
Sid
92 4Runner SR5 3.0 standard tranny
4.88 gears, rear elocked, OME coils, SAW Tbars, allpro rock sliders and rear bumper, custom made front, downey v6 headers ...
Re: I'm Locked with new gears! [Re: dragr1] #311090 09/07/03 07:30 PM
How did the wiring kit work out from inchworm? Was it easy to install? what did it included? any hang-ups?
Re: I'm Locked with new gears! [Re: Sid's Toy] #311091 09/07/03 10:08 PM
dragr1 Offline OP
Sid
I tested the locker motor before I bought it, but I did not test the wiring?
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6338 MB (Peak: 0.7572 MB) Data Comp: Off Server Time: 2026-05-29 15:34:31 UTC
