Removing Bumpers #312482 09/07/03 07:47 PM
brntrt Offline OP
OK, got the Eibachs on with no trouble. Now I am planning on putting on the 1.5" body lift. How much trouble is it to remove the bumpers and can anyone give me some info on how best to approach it? Thanks in advance
Mark Brown
2002 Sportage 2 Door
Eibach lift,Coil Spring spacers, Body lift, K&N, 9.50x30 M/T
Re: Removing Bumpers [Re: brntrt] #312483 09/07/03 09:59 PM
Dave Scott Offline
2 main bolts each side that you have to get to from up underneath and behind the bumpers and remove the nuts for. you may also have to remove the inner fender plastic junk and any sort of splash guard. oh, and also a bracket from the frame to the edge of the bumper both front and rear, sort-of a stabilizing bracket.
Re: Removing Bumpers [Re: Dave Scott] #312484 09/08/03 02:17 AM
brntrt Offline OP
Hey Dave
That plastic crap has fasteners that look as if they are phillips heads screws but they are not. Do you just yank em out and replace them?
Mark Brown
Re: Removing Bumpers [Re: brntrt] #312485 09/08/03 02:01 PM
Dave Scott Offline
grab them with needle-nose pliers and unscrew them or you will mess them up. or you can just yank them, i did, broke about half of 'em, but like i care! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Removing Bumpers [Re: brntrt] #312486 09/08/03 05:01 PM
Remove the plastic "screws" with a screwdriver then the 'keeper' will pop right out. You can re-use everything. A much better (reuseable) design than the old "christmas tree" clips of yester-year.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6042 MB (Peak: 0.6682 MB) Data Comp: Off Server Time: 2026-06-07 05:00:26 UTC
