You would think that I! f less fuel is needed to pass through the injectors; you would gain enough extra fuel to compensate for having stock injectors. So why the larger injectors? If you get 15mpg before and then 20mpg after, thatÆs a 33% increase. You'd think it would be like have 33% bigger injectors. You see where I'm coming from..... Just a thought, straighten me out if needed.
EFI systems don't work that way... The ECU is programmed to utilize the system as designed ...When you add larger injectors or raise the fuel pressure, and you don't tell the ECU the injectors are of a certain spec via reprogramming or fooling the ECU with an air/fuel tuning module... the ECU will compensate for the larger injector by cutting back the fuel delivery if it falls within the correction capabilities of the ECU... The ECU can compensate up to +/- 15% or more! Then you start getting into trouble... Unless the engine is running very lean... then larger injector can help bring the system back to within that 15% ratioà So just slapping in larger injectors into a stock system with the idea of larger means more, is just a waste of money, if you donÆt do the tuning module or reprogram the EPROM along with ità IÆve even put resistors in series or parallel in the coolant temp circuit, AFM and even air temp circuit to fool the ECUà anyway thereÆs more to it than one can imagine. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
The fuel atomizer on the other hand is doing something totally different... basically your getting a better mix of fuel and air which results in a more complete combustion and better fuel economy... Fuel injectors donÆt have enough time to atomize the fuel to that extent... by passing fuel in vapor form into the plenum camber your giving the fuel more time to mix with incoming air... But! the ECU will cut back the injector on time to compensate for the fuel vapor the atomizer pumps in via the PVC hose.
car designers where doing something similar with the throttle body injection..., which was, known for its fuel economy.
Best of luck... I'm always interested in innovative ideas, so to those who install one of these systems... I would be interested if thereÆs a trade off for performance on a normally aspirated engine. <img src="/forums/images/graemlins/cheers.gif" alt="" />
