Low/high beams together #317016 09/17/03 04:32 AM
G
GeroniMoe Offline OP
I know I've seen this discussed before - but I used "search" and couldn't find it...
How do I make it so that my low-beams stay on when my high-beams are on?
Thanks!
- Scott
***ADDED***
I know it's doable - when switching from low to high beams, there's a clean switch, the lows turn off when the highs come on - but when you switch BACK, the lows come on while the highs are still on, and the highs only turn off when you release the "stick" <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Low/high beams together [Re: GeroniMoe] #317017 09/17/03 05:15 AM
Depending on how they are wired you might be able to do it just by taking the ground for the lights straight to metal. Usually it runs through the switch and it disconnected when you turn the high beams on. Not totally sure on the Rodeo but it's an easy thing to try.
Re: Low/high beams together #317018 09/18/03 06:36 AM
boyd Offline
I wouldn't advise hooking up your hi and lows together. Not only is it illegal, it also shortens the life of the bulb, causes the wiring to melt and puts too much load on the battery and alternator.
Boyd
86 Isuzu Trooper 2-door C223
82 Isuzu Gemini Coupe 2.3 G200
Re: Low/high beams together [Re: boyd] #317019 09/18/03 02:02 PM
RobG Offline
I've only heard of this mod on Chevy's where hi and low beams are actually seperate lights. I suppose you could figure out a way to do this on Isuzu relatively easily, don't know if it would be a good idea though.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 38x13 TSLs, spooled D60 front, 14bff rear locked by detriot, high steer w/ hydro, dual Isuzu tcases.
Re: Low/high beams together [Re: GeroniMoe] #317020 09/19/03 02:40 AM
maxwell417 Offline
Run a switched relay to the low beams. I've used hi/low in same bulb for many years with no problems. As far as legality, no different than driving lights. As long as you dim the high beams when you should, no one will ever know. Bulb life is not an issue, even when I was running H4s.
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: Low/high beams together [Re: maxwell417] #317021 09/19/03 06:41 AM
randii Offline
I've lit dual filaments for a while... I definitely experienced shorter bulb life, I suspect because of the increased heat. On an earlier vehicle that I bridged similarly, I burnt out the ground, so I doubled-up on my Amigo and ran a parallel heavier-guage second ground. No failure yet.
What I did was study the wiring diagram to identify the two signal leads for the high and low beams (each switches a headlight relay) and then switch them together. This way I can run high, low, or both. I eventually ran a diode inline with the switch so that the current ran through the switch only from high to low... that way I could still use the 'dip headlight' feature and switch back to low beams normally.
Randii
Randy Burleson
4x4Wire Managing Editor Emeritus
Mongrel Isuzu Amigo
Re: Low/high beams together [Re: randii] #317022 09/19/03 05:42 PM
P
pu12en12g Offline
Bump on the shorter bulb life.
Running both might work on the stock bulbs, but I know that on high wattage bulbs like mine, it is a no no, because I would be running 180 watts = too hot.
1999 Isuzu Amigo 4WD
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6148 MB (Peak: 0.6934 MB) Data Comp: Off Server Time: 2026-06-20 22:58:51 UTC
