Page 1 of 3 1 2 3
Replaced my dash illumination and installed dash bezel . . . #317587 09/18/03 04:40 AM
P
pu12en12g Offline OP
Before:
[Linked Image][Linked Image]
After:
Click here for more Photos
Before (dash bulbs barely lit anything up):
After:
1999 Isuzu Amigo 4WD
Re: Replaced my dash illumination and installed dash bezel . . . [Re: pu12en12g] #317588 09/18/03 05:12 AM
Smiley Offline
NICE! --- It looks really clean and neat, improves the illumination, and updates the overall appearance too! <img src="/forums/images/graemlins/kewl.gif" alt="" />
I sure wish I could find something like that for my `97.
I'm soon gonna be dismantling the whole assembly anyway, in order to replace a burned-out bulb... But as best as I can tell, there just doesn't seem to be such a thing out there that's designed to fit mine (Nothing for one with a tachometer anyhow). <img src="/forums/images/graemlins/frown.gif" alt="" />
Cheers! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Smiley
Six Isuzus, so far... still have three of them.
Re: Replaced my dash illumination and installed dash bezel . . . [Re: Smiley] #317589 09/18/03 12:03 PM
Canucklehead Offline
Look on EBay. I've seen bezels for our Rodeos before.
Steve
'97 Rodeo 5spd. 3.2L SOHC V6 4WD
Re: Replaced my dash illumination and installed dash bezel . . . [Re: Smiley] #317590 09/18/03 01:27 PM
Smiley Offline
Which brings me back to:
Truly... If you ever happen to see one that will fit a 1995.5 - 1997 Rodeo, with the side-by-side Speedo & Tach, and the 2 + 2 Flanking Gauges (Alt. & Temp. on the left, and Oil Pres. & Fuel on the right), PLEASE post something about it!
TIA!
Smiley <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Replaced my dash illumination and installed dash bezel . . . [Re: Canucklehead] #317591 09/18/03 01:28 PM
rubo Offline
Smiley, check this out
web page
I know it says Trooper, but i have taken my dash apart & it's absolutley the same.
rubo
"If i can't crawl over it, i'll fly over it"
rubo
'96 Amigo 4x4, 3.2L V6, 4L30E, D44 rear, SOA, 1" BL, undergoing surgery.
'00 Rodeo LS 4x4, 3.2L V6, OME 919 Springs, front cranked to match,1" BL, 265/70x16 Scorion A/T's.
Re: Replaced my dash illumination and installed dash bezel . . . [Re: pu12en12g] #317592 09/18/03 02:52 PM
RodeoXS Offline
Where did you get the bezel?? I have a 92 also with the same interior as you and would be interested in something like that. Looks good.
BTW...did you run into any snafu's while removing dash?
George <img src="/forums/images/graemlins/nana.gif" alt="" />
92 Rodeo XS 4x4
HomePage
Re: Replaced my dash illumination and installed dash bezel . . . [Re: rubo] #317593 09/18/03 06:34 PM
Smiley Offline
Rubo, if I'm following, what youÆre saying is that THESEà
àwill fit a Rodeo, simply if the inserts are rearranged (???)
Hmmmmmmmmmmmmmmmà Can anyone out there confirm this?
(Other than their actual placement, they really DO look the same.)
If it turns out it's as easy as that, then in combination with those brushed aluminum dash & interior trim pieces that you posted about last week, this gauge face set would look Hella-cool! <img src="/forums/images/graemlins/kewl.gif" alt="" />
<img src="/forums/images/graemlins/cheers.gif" alt="" />y
Re: Replaced my dash illumination and installed dash bezel . . . [Re: Smiley] #317594 09/18/03 06:47 PM
Almost the same,
pay attention on the Oil/pressure meter the scale is different.
Re: Replaced my dash illumination and installed dash bezel . . . [Re: Smiley] #317595 09/18/03 06:54 PM
This picture doesn't show the placement. I believe that the 94/95 Trooper instrument cluster is laid out the same as our Rodeos. Can anyone with that year Trooper confirm this? <img src="/forums/images/graemlins/cheers.gif" alt="" />
Steve
Re: Replaced my dash illumination and installed dash bezel . . . #317596 09/18/03 07:07 PM
Smiley Offline
Almost the same, pay attention on the Oil/pressure meter the scale is different.
So it is - Good eye!
Although, I'm not so sure that the replacement unit wouldn't be the better of the two. --- Mine just has dots and lines between the highest & lowest indications... Having some actual numbers (even some wildly-inaccurate ones) would be kinda nice.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6426 MB (Peak: 0.7708 MB) Data Comp: Off Server Time: 2026-06-07 11:23:23 UTC
