Page 1 of 3 1 2 3
Has anyone replaced our traction bars? #320709 09/24/03 11:34 PM
sveltax Offline OP
These are the bars running forward from the rear axle to the body. I've seen some beefed up bars on a lot of domestic trucks, do we have anything like them for our Zus?
02 Axiom, 2.5" Indy4x Lift, Rancho 9000sx, 265/70 17 ATs, awesome Shrock Works sliders, flipped ball joints and a PV muffler.
Re: Has anyone replaced our traction bars? [Re: sveltax] #320710 09/25/03 07:51 AM
Smiley Offline
Well, not to sound like a smart <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> , but...
(No pun intended... HONEST!)
I think the bigger question would be:
Has anyone ever heard of someone who's had even a bit of trouble out of their original OEM locator bars?
I honestly don't know, but I can tell you that I have NEVER seen anyone talking about it.
HTH
Smiley <img src="/forums/images/graemlins/cheers.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: Has anyone replaced our traction bars? [Re: Smiley] #320711 09/25/03 01:13 PM
i have the calmini lift - it comes with new 'trailing arms' for the rear end. mainly you get urethane bushings and the top arms are contoured to clear the gas tank and frame so that you can acheive maximum suspension travel - probably gain 4 to 5 inches in droop. as for strength i can't imagine you need anything stronger than stock
Re: Has anyone replaced our traction bars? [Re: sveltax] #320712 09/25/03 01:17 PM
U
unirevolt Offline
Matt - 92 Rodeo LS (sorta)
tell tail signs
It's no fun to climb the ladder when the rungs on the ladder are bent - The Recipe
Re: Has anyone replaced our traction bars? [Re: unirevolt] #320713 09/25/03 02:47 PM
BigSwede Offline
Well I don't know about Rodeo etc., but the locator bars (I assume we are talking about the bars that reach forward from the axle to the frame) on my Trooper are very stout...I have banged them on rocks several times at Moab with no discernable effect.
Although I should relate a little story - earlier this summer I was laying under the Trooper, changing the oil. While I was waiting for the oil to completely drain, my gaze wandered down the underside to the rear...suddenly I noticed one of the locator bars was bent! My mind raced as to what to do to fix or replace this problem...until I looked at the other one and realized they were both "bent", and in fact came that way from the factory... <img src="/forums/images/graemlins/drunk.gif" alt="" />
Serenity now!
Re: Has anyone replaced our traction bars? [Re: sveltax] #320714 09/25/03 06:32 PM
Bansil Offline
Well I'll give my .02
I do not have a choice but to make a link for the drivers
side.That is one of my issues before Uwharrie.Right now
she is driving it with the rear suspension compressed
about 1".I am using the stock shocks as limiters for the
rear suspension <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />.If you take the rear
shocks off the arm hits the gas tank and actually holds the
spring from extending about 1/2" truck sits lopsided
with arm on tank.
Lisa is bringing another bar home tonite for me to modify <img src="/forums/images/graemlins/evil.gif" alt="" /> It rides like crap now <img src="/forums/images/graemlins/shiner.gif" alt="" /> if you go over railroad tracks at about 2mph the back tires actually will bounce off the ground. <img src="/forums/images/graemlins/shocked.gif" alt="" />
The trackarm/panhard bar is also getting lowered 4"
to unbind the Drv-link.....
I'll have some used rear shocks for sale shortly <img src="/forums/images/graemlins/notooth.gif" alt="" />
they will be about 1/4" longer than stock.
Doug
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
That was part of my question... [Re: Bansil] #320715 09/25/03 09:34 PM
sveltax Offline OP
When I raised the back of my Axiom with OME 912 springs I encountered the same issue, the traction bar hitting the gas tank and not letting the rear axle drop all the way down. I guess a bent or rewelded bar that would clear the tank would definitely let the rear axle have more articulation.
Wig... #320716 09/25/03 09:37 PM
sveltax Offline OP
When I was looking for a lift kit I don't think Calmini had the available bent traction bar, when did you get your lift? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Has anyone replaced our traction bars? [Re: sveltax] #320717 09/26/03 02:28 AM
Bansil Offline
I looked at the calmini bar I don't think it has
enough of a drop in it...using bushing sleeve to
compare drop, for my application...My sigs is off a
little it's 3 1/2" in front and not sure how much in
back 912's + 2" spacers it more like 5" in back.
Doug
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: Has anyone replaced our traction bars? [Re: Bansil] #320718 09/26/03 02:41 AM
StinkBug Offline
I think what you guys are talking about are actually suspension links and not traction bars. Traction bars are usually an add on for leaf sprung vehicles to cure problems with axle wrap.
Anyways back to the topic. Its funny Gilbert was just over at my shop on tuesday night and we were having a conversation on this very topic. He's had a lot of problems repeatedly bending his lower links and was looking to have beefier ones made. I told him I could do it for him, but I'm wondering if there are others that would be interested in them. I know I've seen a number of late model troopers bend links (I watched Bruce bend his in moab last year I think). They would be easy enough to replace with something stronger but I've yet to see anyone do it. IIRC the calmini kit for the amigos replaces the UPPER links to create clearance for the gas tank, but the stock lowers remain. So is anyone interested in seeing these get made?
Mods, I hope i'm not breaking any rules by asking this, but if there is a problem let me know and I'll delete it.
Dallas
[color:"blue"]Crew Chief, RedBull RockCrawling Team [/color]
[color:"red"]StinkyFab Custom Metal Creations[/color]
Project StinkBug
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6391 MB (Peak: 0.7641 MB) Data Comp: Off Server Time: 2026-11-02 19:25:57 UTC
