How many Leafs? #323215 09/30/03 02:48 AM
Stinson Offline OP
I just got an 86 4x4 pickup and I was wondering how many leafs it has stock. My rear sits up a little higher than the front and I was wondering if maybe someone had added an ad a leaf. It pretty stiff. 4leafs total. Thanx Stinson
Re: How many Leafs? [Re: Stinson] #323216 09/30/03 03:04 AM
mt_goat Offline
Your front torsion bars may just need adjusting. They sag over time and you loose height. Here is a tech article on adjusting them http://www.off-road.com/toyota/tech/torsion/index.htm
Sorry, I can't remember how many leafs I had stock. If you don't want to raise the front but would rather lower the rear to match the front, you can remove a leaf.
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: How many Leafs? [Re: Stinson] #323217 09/30/03 03:41 AM
4Crawler Offline
I think most pickups have 4 leaves, main leaf, full length military wrapped 2nd leaf, a shorter 3rd leaf and an overload leaf on the bottom. Some of the earlier pickups ('83 and earlier) had 2 overloads, a short one and a longer one.
Re: How many Leafs? [Re: 4Crawler] #323218 09/30/03 04:49 AM
Frankenyota Offline
4Crawler called it, my stock 86 leaf pack was exactly as he described.
1986 4X4, 1991 22RE, 5.71 gears,ARB Rear, aux fuel tank, 3mm O/S TB/intake, engnbldr cam, LCE header, magnaflow w/2.25 exh. custom 4 color paint job :-P 33X12.5 Goodyear MT/Rs
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6049 MB (Peak: 0.6608 MB) Data Comp: Off Server Time: 2026-06-07 03:16:31 UTC
