Why won't my truck charge the battery? #324335 10/02/03 02:46 AM
airfooter Offline OP
'84 4Runner - I've got just over 12 volts at the battery (freshly charged) with truck running (or not). I have now installed 2nd new alternator and voltage regulator. I have new cables, good ground to fenderwell and block, good fuses, open line (no resistence)on any wire between alt and VR, belts are good... My CHARGE lite and BRAKE lite in dash used to "flicker" together before they both started staying on. I travel alot, and have resorted to dual cycle batts, charging them when I stop and switching them when the lights get too dim to drive.
Where else can I look for a problem?
Jason
1984 4Runner - V6 rear axle (locked by Lincoln), header, plenty of body cancer!
Waiting for install: x-over steering, dual 'cases, twin-stick, 3" body & drivetrain lift, rear springs up front
Still need: rear springs, 35" MT's, bumpers/sliders
2001 F350 - 7.3 110k miles on WVO conversion now!
Re: Why won't my truck charge the battery? [Re: airfooter] #324336 10/02/03 02:56 AM
ldivinag Offline
when the truck is running you should measure 14 volts or higher at the battery posts.
if not, the alternator aint doing its job...
check the belt. it is "tight" enough?
measure the voltage at the post of the alternator. then at the battery. voltage drop should be very small.
but again, alternator should be putting out 14 or more volts...
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: Why won't my truck charge the battery? [Re: ldivinag] #324337 10/02/03 03:04 AM
Not being a sparky, I had a like problem that turned out to be a solenoid, replaced everything but...
of course that was on an old small block Ford years ago.
Electrical things are a pain and sometime worth having a pro do it.
Some parts stores advertize that they will check you charging system for free...
Re: Why won't my truck charge the battery? [Re: ldivinag] #324338 10/02/03 01:38 PM
Belts are tight. No wires are broken either. There are 4 wires on my alternator. Anyone know what voltage to check for? Advance Discount Auto parts "checked" my charging system and said it did not work (their "machine" is a voltmeter/ammeter). They could not tell me if it was alt, volt. reg. or something else. Since alt and vr were "lifetime" they just gave me new ones. I am kicking myself for not having them bench test the old one... (I talked parts dude into letting me take new one home and change it, and then brought old one back).
Oh yeah, while visitng my dad, he insisted we unhook the battery to see if truck still runs... After replacing Igniter, several fuses and ruining my aftermarket tach (read a couple hundred bucks total), I now know why they always said this is a BAD IDEA!
Re: Why won't my truck charge the battery? [Re: airfooter] #324339 10/02/03 02:14 PM
ZUK Offline
sounds like it's charging now.
mostly stock
Re: Why won't my truck charge the battery? [Re: airfooter] #324340 10/02/03 06:31 PM
Esquire812 Offline
Yup, never a good idea to let the magic smoke out of any electrical component. No more smoke...no more work. <img src="/forums/images/graemlins/notooth.gif" alt="" />
I tend to bring the spark outta electrical things myself...man does it hurt. Both physically and financially. Hope dad at least sprang for some steaks and beers after your little adventure.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: Why won't my truck charge the battery? [Re: Esquire812] #324341 10/02/03 09:37 PM
Red_Chili Offline
Toyota Section Staffer
Common mistake, that 'remove the battery from the circuit' trick. 'Gee, it worked on my '66 Fairlane!'
As a Dad, lemme say to him: You are on the hook for your kid's parts, man.
-Bill
Re: Why won't my truck charge the battery? [Re: Red_Chili] #324342 10/02/03 09:44 PM
Esquire812 Offline
Dang kids is expensive arent they! lol Now when it comes to vehicles the whole family comes to me, but my stepson is into guitars etc. I wont even hold em let alone start messing with all them electronic buttons, dials and thingy-majiggies. His last guitar cost over $1000...what ever happened to them bigassed box kind ya didnt have to plug into a substation to play..ya know like the kind Elvis played! hehehe
*Hey airfloater, did you say you replaced the regulator thingy? Pretty sure 84' had an exterior regulator right...kinda like a big black heavy box thing? If you havent tried that see about a replacement. I had a nissan thats electrical was all FUBAR'd and the regulator would test out fine. When in all reality it was until it warmed up then sent stray currents all over hell. I shoulda bought stock in BUSS fuses back then...used to carry multiple boxes of varied sizes just incase I had to use a turn signal hehehe. If you need a regulator for testing purpose give me a yell..I have one from an 86' parts lot I acquired.
85' Sillyca 22R-Esq
Re: Why won't my truck charge the battery? [Re: Esquire812] #324343 10/02/03 09:48 PM
Rauch_Off_Road Offline
Wow Darin, are you sure you aren't too old to drive? <img src="/forums/images/graemlins/lol.gif" alt="" /> lol. Them there electronics need lotsa learnin. <img src="/forums/images/graemlins/cheers.gif" alt="" /> .
(Sorry, I just couldn't resist)
(aka suprathepeg, aka Sean)
Re: Why won't my truck charge the battery? [Re: Rauch_Off_Road] #324344 10/02/03 09:53 PM
Esquire812 Offline
Supra.... <img src="/forums/images/graemlins/bird.gif" alt="" />
LOL - Hey man I'll be 32 in November...step son is 16 you do the math. Mama is just a bit older. Gotta love our life situation, the boys dad is giving us the rims off his 98' 4Runner (16" baby!!) that he recently sold when he bought his 03' Tacoma double cab with S/C'd 3.4L. And we get along great...I get to drive the Taco this weekend! <img src="/forums/images/graemlins/nana.gif" alt="" /> hehehe
85' Sillyca 22R-Esq
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6436 MB (Peak: 0.7687 MB) Data Comp: Off Server Time: 2026-11-16 08:42:48 UTC
