CD stuck in the CD player #331174 10/14/03 02:45 PM
chitrod Offline OP
I have a CD that is stuck in my factory CD player. Does anyone have a clue as to how to get it out? It's not even showing up that it's in the player, but I know it's there because if I try to put in another CD it won't go in. I tried to push the CD eject button and held it for several seconds, with no luck. Anyone know what I should do?
ChitRod 1996 Toyota 4runner SR5 brushguard, safari rack, SRB lights and 265/75/16 Terra Grapplers--Sold, but missed.
Re: CD stuck in the CD player [Re: chitrod] #331175 10/14/03 03:12 PM
This used to happen to me in my stock '95 4Runner cd player occasionally.
Get some tweezers and try to pinch as close to the edge of the cd as possible (so as not to scratch it). If you shine a flashlight, you should even be able to see the cd edge in there.
Works like a charm.
Re: CD stuck in the CD player #331176 10/14/03 06:03 PM
chitrod Offline OP
ok i'll give it a try, I sure hope the CD player isn't messed up I want xm radio, but I don't want the expense
Re: CD stuck in the CD player [Re: chitrod] #331177 10/14/03 07:28 PM
bard Offline
Will it pop out on it's own if you disconnect power to it for a minute? Used to work on my 93.
Re: CD stuck in the CD player [Re: bard] #331178 10/14/03 10:18 PM
chitrod Offline OP
To do that wouldn't I have to disconnect the battery,and then have to reset the clock and radio? I'll try that if tweezers don't work, it's a burned CD anyway (and yes it has worked in there before numerous times, so that isn't the reason it's stuck.)
Re: CD stuck in the CD player [Re: chitrod] #331179 10/14/03 10:23 PM
does your burned cd have a sticker label on top?
I had lots of problems with those getting stuck in my 95 stock stereo. To the point, in fact, that I kept tweezers in the car for when I played them.
Bill
Re: CD stuck in the CD player [Re: chitrod] #331180 10/15/03 08:23 PM
bard Offline
That or pull the lead from the back of the stereo. Batt is easier.
Re: CD stuck in the CD player #331181 10/16/03 03:53 AM
chitrod Offline OP
no I tried the sticker label once, but it almost came off in the player about 2 years ago so I haven't used one since.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6140 MB (Peak: 0.6949 MB) Data Comp: Off Server Time: 2026-06-17 01:45:06 UTC
