FRONT END NOISE #331484 10/14/03 10:20 PM
MY FRONT END MAKE A BANGING NOISE OVER BUMP , TOYOTA SAID IT MY HALF SHAFT NEED TO BE REPACK, THEY WANT 425.00 TO DO THAT. I WANT TO KNOW HOW HARD IS IT TO DO. I HAVE A 94 TOYOTA V6 WITH 39000 MILES ON IT
Re: FRONT END NOISE #331485 10/14/03 10:39 PM
mtnfreak Offline
I see a couple of issues here. 1) 39K on a '94. Are you sure? 2) If so, the front end should be nearly mint.
Look around under the truck, look for anything worn smooth &/or shiny. Grab onto everything that you can and give it a good push/pull/twist. Hope you find the problem before dropping $425.
'89 4Runner, V6, Auto, 180K, Some stuff's stock, some isn't.
Re: FRONT END NOISE #331486 10/14/03 10:43 PM
OOP'S Offline
First off, Why are you yelling!!! NAPA has the complete Half shaft, just get one of those. I have no Idea what they cost. Fixing it yourself depends on how mechanical you are, for me it's about a 2 on a scale of 1-10. Check to make sure your shocks are not loose before going and getting the half-shaft. I have never had a halfshaft bang only when I hit bumps!!! I had one that was broken at the stub shaft and it did not make any noise, even when it was in four wheel drive. <img src="/forums/images/graemlins/lol.gif" alt="" />
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: FRONT END NOISE #331487 10/14/03 10:58 PM
dannym Offline
What kind of banging noise is this exactly? It could just be the factory installed pos steering stops that wore out after the first 100 miles... when turning over a bump those trucks can produce horrible noises if your wheel is cranked all the way.... but it sounds like toyota diagnosed your problem, and they know more than i do... that was just a problem i had with bumps and noises.
danny
1994 4x4 Black ExCab Toyota Pickup... i have some big tires in the bed of my truck, and some nice shocks in a box at home <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: FRONT END NOISE [Re: dannym] #331488 10/15/03 12:26 AM
it sound like a broke shock. i just change them last week
Re: FRONT END NOISE #331489 10/15/03 01:00 AM
mt_goat Offline
Those 39000 miles must have been all rough roads. Sounds like she was rode hard and put away wet. Or maybe the speedo cable was disconnected for just a few miles. <img src="/forums/images/graemlins/notooth.gif" alt="" />
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: FRONT END NOISE [Re: mt_goat] #331490 10/15/03 02:39 AM
mechanic58 Offline
I think he may have left off a ZERO. <img src="/forums/images/graemlins/notooth.gif" alt="" />
2007 Ford F150 Supercab
Re: FRONT END NOISE [Re: mechanic58] #331491 10/15/03 03:00 AM
shawn p Offline
my 95 has 74,000 miles. Maybe an old person owned it <img src="/forums/images/graemlins/drunk.gif" alt="" />
2006 tacoma
SR5
4x4
V6 Auto
Re: FRONT END NOISE [Re: shawn p] #331492 10/15/03 05:45 PM
425???? I just bought a used 1/2 shaft for 45 bucks. Use the Toyomart or toy wreckers in Sacramento <img src="/forums/images/graemlins/shame.gif" alt="" />. Your front end WILL make noise and mine always does, just make sure you are greased, tigght and have replacements if needed.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6191 MB (Peak: 0.7051 MB) Data Comp: Off Server Time: 2026-11-02 21:49:56 UTC
