Clutch Question
#331598
10/15/03 02:14 AM
I'm in the process of changing out my transmission (W56), and I already knew the throwout bearing was going out....so I have one on hand to replace that also.
When I removed the transmission and started inspecting the clutch, the first thing I noticed was that there was alot of WEAR where the throwout bearing contacts the "spring loaded fan-fingers" of the clutch. This is a new Marlin clutch that I installed maybe 5,000 miles ago. Is this normal?? Or, is it possible that the bad throwout bearing has caused this to wear abnormally fast??
Now, my next question is the biggy.....does this wear change my methodology of simply swapping out the throwout bearing? Will the new throwout bearing be damaged or not operate correctly with this worn spot in the clutch?? I don't have a micrometer, but I'd say the clutch fingers are worn down approximately 1/64"....somewhat substantial. Even on my old ass clutch that I replaced, I didn't have wear like this....perhaps this was caused by me being stupid with my duals?? I don't know...anyways.
Thanks for any insight... Max
Re: Clutch Question
[Re: Ishikawa]
#331599
10/15/03 02:29 AM
That wear is unusual as you have suspected. Depending on how bad it is, I'd be afraid to put that pressure plate back in service. The wear was most likely caused by your worn out throw out bearing. Weather or not it'll affect your new throw out bearing is anybody's guess. I used to be pretty good at getting one of those trannies out...bout 30-40 mins or so. LOL. So I'D (in capital letters) prolly stick it back in...but then again, it may leave you on the side of the road. Don't think those pressure plates are too awful expensive. Good luck. <img src="/forums/images/graemlins/notooth.gif" alt="" />
2007 Ford F150 Supercab
Re: Clutch Question
[Re: mechanic58]
#331600
10/15/03 02:44 AM
Well if it was me, as busy as I stay and what little time to wrench on my stuff, I'd slap a new pressure plate in it while the tranny is down. The wear you mentioned is abnormal. You never know, might last 100,000 miles or might last till around 40 miles from the nearest pavement.
John
John Luttrell 2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
Re: Clutch Question
[Re: john_luttrell]
#331601
10/15/03 04:14 AM
Cool...thanks guys, that's what I figured. Just checking the sanity...since it's not always there <img src="/forums/images/graemlins/smile.gif" alt="" />
Max
Re: Clutch Question
[Re: john_luttrell]
#331602
10/15/03 04:32 AM
Put in a new clutch, and remember to get th flywheel resurfaced, new clutch=flywheel resurface, TO bearing, and pilot bearing in my book!!
"Serenity through Sobriety"
Re: Clutch Question
[Re: Ishikawa]
#331603
10/15/03 06:06 AM
did you not replace the TO bearing when you replaced the clutch last... Big no no if you didn't...
If you did....
I'm not trying to insult you but did you put the bering on the right direction? putting it on backwards would cause some major problems.
Josh
1986 Toyota 4x4 22wEBer Ported EB Offroad H/O Head "Josh Cam" Ported Intake & Weber38mm Carb LCE Header & 2.25in Exhaust RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
Re: Clutch Question
[Re: ArbitraryNotion]
#331604
10/15/03 06:20 AM
No worries insulting me, I do everything bass-ackwards <img src="/forums/images/graemlins/notooth.gif" alt="" />
Well, the truth of the matter is that when I intalled the new clutch to begin with....I completely forgot about the TO bearing until the duals and driveshafts were bolted on and I had driven about 1,000 miles. By then, I said f#&@ it....oh well. Life's a bizatch, then you die. Funny thing is I replaced the pilot bearing, got the flywheel surfaced, etc....and even had the TO bearing. I found it one day when searching through some of my "spares" and thought "OH SH#%! I didn't put the TO bearing in". LOL!
I'm gonna just order a new clutch from Marlin tomorrow, no biggie. Maybe this time I'll remember the TO bearing <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Max
Re: Clutch Question
[Re: Ishikawa]
#331605
10/15/03 02:25 PM
Marlin gave me a 1 year warranty on the clutch I got from him. Call him and see what he tells you. He can probably diagnose the cause of the unusual throw out bearing for you on the phone as I'm sure he's seen it before.
94 SR5 4-Runner 167000 Miles and going strong BJ Spacers, Fj80 coils, MT/R's Lock Right front and rear
Re: Clutch Question
[Re: Ishikawa]
#331606
10/15/03 05:04 PM
I would never ask Marlin to warranty his components that I obviously screwed up. Period.
Max
