Re: Where to get a switch that fits the Toyota slots #331990 10/16/03 09:13 PM
Some switches may be rated at a different amp. than others. If too much current is run through a low amp switch, some nasty results could come to be. Other than that, it shouldn't matter much.
ahhh, ok. Thanks.
Re: Where to get a switch that fits the Toyota slots #331991 10/16/03 11:24 PM
ldivinag Offline
why even bother.
use a relay for everything. if you are running a 20 amps through the switch, why? just send a smaller amount through the switch and have the relay handle it...
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: Where to get a switch that fits the Toyota slots [Re: ldivinag] #331992 10/17/03 01:03 AM
why even bother.
I first tried to use the relay that came with the horn, but it wouldn't work. I then bought another relay thinking that one was bad, but it wouldn't work either, so I just used a switch for a easy fix, got tired of dickin around with it.
Re: Where to get a switch that fits the Toyota slots #331993 10/17/03 02:27 AM
There on E-bay all the time. Do a search for 4runner or toyota tacoma.
Re: Where to get a switch that fits the Toyota slots #331994 10/29/03 11:44 PM
Cebby Offline
Here's a place that has the switches ARB uses:
http://www.waytekwire.com
They are the "Contura" switches IIRC.
1993 4Runner SR5 4WD V6 Auto - under the knife for a 1UZFE transplant
Check out my new Tool and Fabrication forum - www.TOOLandFAB.com
Re: Where to get a switch that fits the Toyota slots [Re: Cebby] #331995 10/29/03 11:45 PM
Cebby I think that's a busted link.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6071 MB (Peak: 0.6918 MB) Data Comp: Off Server Time: 2026-06-18 07:11:55 UTC
