oil pump replacement
#332741
10/17/03 01:21 AM
Hey everyone I just got my motor pulled out to put in a new clutch and timing set and water pump. Now the motor has 130,000 miles on it should I also put in a new oil pump at the same time. Do the realy go bad? what do you think replace or not? thanks joe
Re: oil pump replacement
[Re: traveler727]
#332742
10/17/03 02:11 AM
If the engine is out with that many miles I would change it with a new toyota oil pump. Not that you have to, or that they go bad around that milage, it just seems like a good time for a little preventive maintenance, great time for a timing belt replacement if' it's a v-6.
John
John Luttrell 2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
[Re: traveler727]
#332743
10/17/03 08:38 AM
They rarely if ever go bad. Keep it as a trail spare. Petrolatum and a ziploc.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5934 MB (Peak: 0.6464 MB) Data Comp: Off Server Time: 2026-05-29 15:25:08 UTCValid HTML 5 and Valid CSS
