a new-be rebuilding a 2.6L #333439 10/18/03 09:23 AM
coldrain Offline OP
do any you have any pointers or "got ya's" that could help. The swap of the '86 worked well for 10 weeks before it gave out. Not completely sure what happended, I hope with the help of this site we can find out..
Re: a new-be rebuilding a 2.6L [Re: coldrain] #333440 10/18/03 07:22 PM
hfoobe Offline
Hi Coldrain. We communicated back when I was putting my 2.6 in, replacing the 2.3. I have an 86 Pup. Sorry to hear there were problems. I had some too. Mine seems fine now, running with 2.3 carb and mostly 2.3 stuff on a 2.6 block and head.
Been ten months or so since I put mine in but I remember some things I did, that seemed crucial. Water-pump pulley issues. (Had to use 2.6 water pump, and had a machine shop press the pulley closer down the shaft, needed to match up with 2.3 crank pulley.) Fuel pump changed to electric. Broke a ring right off and had to do the whole job over again....maybe some other things. what is it acting like? I'd like to help if I can. I appreciate all the help I got from this site when mine was on blocks.
Re: a new-be rebuilding a 2.6L [Re: hfoobe] #333441 10/23/03 04:41 PM
coldrain Offline OP
The engine does require a rebuild, I may even require a new block. I was comming back from my holidays and about 10 miles out of town there was clunck noise. I pushed the truck about 2 or 3 miles when it finally gave out. Had the truck towed home. The next day I pulled the valve cover and notice a fair bit of metal bits. I was looking over the engine, the cam gear has a extreme wobble. I suspect the timing belt slipped, not sure as to why. I am praying that block can overbored to remove any possible scratches. I will be pulling the engine out of the truck in mid november.
Re: a new-be rebuilding a 2.6L [Re: coldrain] #333442 10/23/03 06:06 PM
strawmyers Offline
Isuzu Moderator
I would be very surprised if it required a new block. The head is the weak point on these engines.......... the block is unbelievably beefy. They'll put up with a lot more than you would imagine (trust me <img src="/forums/images/graemlins/shiner.gif" alt="" /> )
Sean Strawmyer
Re: a new-be rebuilding a 2.6L [Re: coldrain] #333443 11/07/03 05:59 AM
hfoobe Offline
Not much to say except yikes. Was this a rebuild 10 weeks ago, or a swap of another used engine?
I feel your pain. Like I said though, mine runs great now. there is a light at the end of the tunnel.
Please keep updating this chain. I'm curious what you find. Also I'd like to say I admire a person who sticks with a broken thing and fixes it. Why? I haven't a clue.
Re: a new-be rebuilding a 2.6L [Re: hfoobe] #333444 11/07/03 06:58 PM
marcucci Offline
With a lot of metal bits up in the head I would suspect spun bearings. In that case, I wouldn't even bother with a rebuild- find a used motor, and rebuild that if you really want. The bottom ends of these trucks are rock-solid if there is oil kept in them and they are maintained, you should be able to find a decent used motor and just roll with it. I would inspect it but it shouldn't need rebuilding.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6115 MB (Peak: 0.6822 MB) Data Comp: Off Server Time: 2026-11-17 11:24:54 UTC
