check engine light, odbii code p1441?
#337495
10/26/03 06:59 PM
98 rodeo v6, 67k miles
my check engine light come on and i had the local parts store pull the odbii code. it read p1441 which is evap system flow during non-purge. what does this mean and what should i do? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: check engine light, odbii code p1441?
[Re: mceachrw]
#337496
10/26/03 07:55 PM
Sounds like just a matter of a loose or leaky gas cap. Lots of time the check valve sticks open on'em. About 2 bucks for a new aftermarket one. You have to maintain positive pressure in the gas tank on OBDII compliant vehicles for the evap system to work- or the CEL will come on. G/luck Joel
#337497
10/26/03 08:20 PM
my wife said my three year old had the door to the gas cap open the night before. maybe she loosened the cap as well. anyway, if the cel returns, i'll replace the cap. thanks.
[Re: mceachrw]
#337498
10/26/03 08:23 PM
Yeh Make sure it clicks a couple times.Wifes did that when she first got it.If not then post back. Good luck Doug
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5965 MB (Peak: 0.6541 MB) Data Comp: Off Server Time: 2026-11-16 08:55:26 UTCValid HTML 5 and Valid CSS
