need p/n for longer studs for All-Pro 3/4" spacers
#338825
10/29/03 01:55 AM
Went to get a free balance since I swapped rims recently. the monkeys with the impact wrench cross-threaded and snapped a stud. Since it's non-stock, they didn't know what to order as a replacement. I do know it's a 1/2" stud.
I searched for dorman and stud and spacer, but couln'd find the dorman p/n for the studs AP uses with the 3/4" spacer. I need the number for the stud and the lug nut. Thanks.
AJ 93 Toyota, dana 60, 14-bolt
Re: need p/n for longer studs for All-Pro 3/4" spacers
[Re: AlaskaToy]
#338826
10/29/03 02:14 AM
ok, I called Allpro for ya. Aparently there are two part no. depend on what yr your axle is. the 79-81 has 6 holes rotors and after that it's 8 holes.
dorman part no. early style 6 holes rotors... p/n 610-073 8 hole style...610-144
nuts 1/2x 20
I hope that helps. Need anymore info just chime in.
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are. It's freedom OF religion not from. 95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
[Re: anthony1]
#338827
10/29/03 02:18 AM
Well. damn! <img src="/forums/images/graemlins/cheers.gif" alt="" /> Beers to you. Thanks! I can't believe how elusive that info has been. Thank you very much. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5964 MB (Peak: 0.6502 MB) Data Comp: Off Server Time: 2026-11-16 08:48:43 UTCValid HTML 5 and Valid CSS
