Bad year ? #344500 11/09/03 05:07 PM
Were there bad years for the tacomas ? I am looking to get my first one and I can afford about a 99. Were there any bad year for the tacomas between '96 and '01 or big traits or model changes that are worth putting out the extra 1,500$ to get the next year model ?
Thanks. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Bad year ? #344501 11/09/03 05:21 PM
Also, what year did the TRD model come up ?
Re: Bad year ? #344502 11/09/03 06:40 PM
Tacoma's were introduced in '95, with the TRD becoming available in '98. Brief Toyota history
if you have a dealership run a check on any '95 to '97 Tacos to see if it is affected by the head gasket/sludging recalls, or just stick to '98 or later, you should be ok.
Re: Bad year ? #344503 11/09/03 06:54 PM
redtoy92 Offline
As hounder said the toyota pickup switched over to the tacoma in 1995.5 the TRD package came out in the 1998 models and that is also the year they changed the some of the body. (flush headlights,etc) I havn't heard to much but i know the 95-97 had a few problems. also if you want to supercharge the truck you want a 98 or newer. I also like the look of the 98 and up alot better then the 97. Go with a 98 or up and you will be fine. redtoy92
2003 TRD EXT.CAB V-6 SR5
supercharger+urd fuel mods
6inch fabtech+1RB
35 BFG MT 4.88's Stubbs sliders
Re: Bad year ? #344504 11/09/03 06:55 PM
mechanic58 Offline
Interesting history link there. Now I'm not braggin or anything...but SUPPOSEDLY the Prerunner that I have was the first one sold to the general public. This is what the dealership told me at the time of purchase in Feb. of 1998. I bought it at Bob Baker Toyota in San Diego. Wonder if there's a way I could confirm this? Wouldn't that be something if the very first Prerunner ever sold to the general public was confirmed to have almost immediately been converted to 4WD? LMFAO!!!! <img src="/forums/images/graemlins/lol.gif" alt="" />
2007 Ford F150 Supercab
Re: Bad year ? [Re: mechanic58] #344505 11/10/03 01:14 AM
This should help you out with telling. look for the sequential number and see if it says 0000001
Re: Bad year ? [Re: mechanic58] #344506 11/10/03 02:52 AM
Hiker Offline
VIN will tell you. I would be suprised if you have #1. I read once that most of the first run vehicles go to testing. Reliablility testing by the manufactuer and other organizations. If you do have #1.... could help or harm when reselling it. Collectors may think it's cool. And optimists may think the first vehicle off the line could be problematic... Let us know what you find...
Re: Bad year ? #344507 11/14/03 08:25 PM
rrolsbe Offline
Which engines had the head gasket/sluge problem you refer to for the 95/96 Tacoma's? I have the 3.4L which I think was an option for the 1996 model year Tacoma.
Thanks Much
Ron
1996 Toyota Tacoma XCab 4x4 3.4L
ARB Bullbar & Warn Winch
Super Spring progressive leaf springs
SuperBumper in rear 2" receiver
Moderator Marks factory Bilstein shocks/Front Coils
Albuquerque, NM
Re: Bad year ? [Re: rrolsbe] #344508 11/15/03 03:03 AM
kewlynx Offline
Tacos had nothing to do with the recall. That was the 3.0L and a handful of the 94 3.4L's, for which there was a mailing campaign. HOWEVER, I wonder about some of the 3.4's, now that some of them are starting to get some MILEAGE on them, that this might eventually be a problem.
Meanwhile, mix your antifreeze with DISTILLED water, not tap, and you'll minimize any corrosion. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Read on the recall HERE
I think I must've posted this about 20 times this month! <img src="/forums/images/graemlins/ignore.gif" alt="" />
**ubi apis- ibi salus**
Re: Bad year ? [Re: rrolsbe] #344509 11/16/03 07:11 PM
E
EQuin Offline
Actually, the early 3.4L V6 engines in the 95, 96 and possibly the 97 (although not too sure about the 97) did have headgasket problems, but not to the extent found in the older, infamous 3.0 V6 engines (pre-Tacomas). The headgasket failures in the 3.4's usually resulted in external leaks, as opposed to the more damaging internal leaks prevalent among the older 3.0's.
With that said, there was never any "recall" per se. A recall is usually mandated pursuant to federal law due to safety reasons. Headgasket failures, despite the high cost of fixing them on today's engine, do not usually trigger the safety warnings requiring a federally mandated "recall." Instead, Toyota had some other word for it - I believe it was called a "service campaign" or something like that. For the older 3.0's, the headgasket service campaign was much more extensive and widespread. I'm not sure if Toyota had, or still has, a "service campaign" for the 3.4L, but if so, the repair should be free since the whole purpose of the campaign is to avoid a costly class action lawsuit threatened by disgruntled owners of the older 3.0's and the early 3.4's. The repair consists of replacing the cheapo headgasket that Toyota was using with a "new and improved", more high quality one (the unsubstantiated rumor I heard years ago on the various message boards was that the new gasket was a Fel-Pro one - Fel-Pro has a good reputation of providing quality gaskets).
Hope this helps.
Ed Q.
03 TRD Tacoma Ext Cab 3.4L 4x4
93 Ford Bronco
86 Ford Bronco
47 CJ2A Willys
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6303 MB (Peak: 0.7526 MB) Data Comp: Off Server Time: 2026-06-18 07:14:03 UTC
