How do I REALLY get my fuel injectors clean? #345179 11/11/03 02:54 AM
TooEZgoin Offline OP
I always run with high oct gas. Is using fuel injector cleaner on a regular basis all I need, or do I have to get the stealership to remove them to be properly cleaned?
Re: How do I REALLY get my fuel injectors clean? [Re: TooEZgoin] #345180 11/11/03 04:06 AM
FattyCBR Offline
Have never had mine cleaned still on the engine, but when I've sent them away it made a world of difference with the engine starting right away instead of taking a minute cranking like it used to. If you can afford the downtime I'd send them off. I payed $11/ injector + shipping for them to be cleaned, which is cheaper IIRC than having them cleaned on the truck.
Milan
_ _ _ _ _ _ __ _ _ _ _ _ _
Support our troops!
'98 4R Limited
'82 Toy 4.3 TBI sold
Re: How do I REALLY get my fuel injectors clean? [Re: FattyCBR] #345181 11/11/03 03:23 PM
DRTDEVL Offline
Where did you send them for $11 each? Did they give you new o-rings and seats as well?
Re: How do I REALLY get my fuel injectors clean? [Re: TooEZgoin] #345182 11/11/03 04:41 PM
mt_goat Offline
My local dealer's parts guy told me to go find someone who sells BG injector cleaner. He said it is the only pour-in-the-tank cleaner that works. It ran me about $25/can. I can't tell much difference though so I don't know if they just weren't dirty or what.
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: How do I REALLY get my fuel injectors clean? [Re: DRTDEVL] #345183 11/11/03 11:15 PM
FattyCBR Offline
I sent them to cruzinperformance.com, Rich is a nice guy and will talk to you on the phone even though he runs the shop. The $11 included cleaning, flow testing, new o-rings, isolators, and screens.
Milan
Support our troops!
'98 4R Limited
Re: How do I REALLY get my fuel injectors clean? [Re: FattyCBR] #345184 11/12/03 04:35 AM
ufjaz Offline
I second fatty's post. I've had a couple of sets tested by Rich - very affordable and pleasant experience.
1996, 2wd, auto trans, deck plate, Addco sway bars, 17 wheels, Borla Cat Back, TRD headers, TRD SC, Bilstein shocks, 4.10 regear, TRD LSD, L10 VB/TC/PTS mods, Hayden tranny cooler, FTC1, 305 cc FI, Supra MAF, Walbro fuel pump
Re: How do I REALLY get my fuel injectors clean? [Re: ufjaz] #345185 11/12/03 06:05 AM
kewlynx Offline
I just got a set back to include my CS injector. The difference being that with cleaning, you're not really checking the spray pattern or anything. Cruzin will do a before/after check, and get them all matched up. If you can afford to have the truck down for a little while, go for it! <img src="/forums/images/graemlins/kewl.gif" alt="" />
http://www.cruzinperformance.com
**ubi apis- ibi salus**
Re: How do I REALLY get my fuel injectors clean? [Re: kewlynx] #345186 11/12/03 06:30 AM
What if I were to upgrade to Supra 305 injectors? Would I have to modify anything else, or would my 97 Runner run ok until I could get the additional mods?
Re: How do I REALLY get my fuel injectors clean? [Re: FattyCBR] #345187 11/12/03 12:31 PM
DRTDEVL Offline
What was the turnaround time on the injectors? Would I have them back in less than 10-12 days?
Re: How do I REALLY get my fuel injectors clean? [Re: DRTDEVL] #345188 11/13/03 02:03 AM
FattyCBR Offline
DrtDevl: If you call Rich he'll tell you how busy he is and estimated turn around time. From what I remember there is the regular price where they get in line when the package gets to his door and it gets done once it's its turn. And then I think he had a hurry up price, but I could be wrong about that.
So it's a function of how much you want to spend for shipping there and back. When I did everything ground it took about 2-2.5 weeks total both times. If I had overnighted them it would have dropped about 7-9 days because I was using Fedex Ground.
TooEZGoing: In order to run the larger injectors you need a fuel controller (s-afc, s-afr, ftc, smt).
Milan
Support our troops!
'98 4R Limited
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6333 MB (Peak: 0.7402 MB) Data Comp: Off Server Time: 2026-06-20 16:36:17 UTC
