3VZ-e rear main seal??? #346818 11/13/03 05:24 PM
corvettelvr73 Offline OP
Hey, New to the forum.
I was wondering if leaking rear and front main seals are a common problem?
I have a 95' 4-runner with the 3.0 V6 and 97,500 i think the rear main seal is leaking not bad yet. My dad also had a 92' truck with the 3.0 V6 and it developed leaks at around 100,000 miles. <img src="/forums/images/graemlins/confused.gif" alt="" /> Could it be the oil lines instead? How do you check or should i just wait untill it drips enough for people not wanting me to park in their driveway? <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: 3VZ-e rear main seal??? [Re: corvettelvr73] #346819 11/13/03 06:14 PM
code33 Offline
The rear main seal is more prone to leak.
What you should do is clean/degrease the entire area. Drive it around for a few days and see where it is originating.
Classifieds & Suzuki Moderator
Re: 3VZ-e rear main seal??? [Re: corvettelvr73] #346820 11/13/03 07:06 PM
mtnfreak Offline
Valve cover gaskets also tend to leak in the back. Looking up from the underside, this leak often looks like it's coming from the rear seal. Tough to see from the top without a mirror or a long, flexible neck.
'89 4Runner, V6, Auto, 180K, Some stuff's stock, some isn't.
Re: 3VZ-e rear main seal??? [Re: corvettelvr73] #346821 11/17/03 10:32 PM
O
oldsub86 Offline
Just a recollection of another post on this forum a while ago. I think there is an oil cooler on the left side of the engine behind the oil filter that tends to leak. There are gaskets that can be changed to fix it if that is where the leak is.
1995 V6 SR5 5 speed 4X4 - 4Runner - dark blue
Re: 3VZ-e rear main seal??? [Re: oldsub86] #346822 11/17/03 11:50 PM
mtnfreak Offline
Yep, kind of a dirty brass color on my engine. About the same diameter as the filter, but only sticking out an inch or so.
Re: 3VZ-e rear main seal??? [Re: oldsub86] #346823 11/18/03 08:27 PM
code33 Offline
Yes, there is an oil cooler on models with A/T.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6080 MB (Peak: 0.6780 MB) Data Comp: Off Server Time: 2026-06-17 13:45:40 UTC
