Noisy Power Steering Pump #351132 11/21/03 07:43 PM
airfooter Offline OP
When its cold out (below 40 degrees F) the power steering pump is very noisy on my '84 4Runner. Once engine warms up it quiets down.
What would cause this?
-Jason
1984 4Runner - V6 rear axle (locked by Lincoln), header, plenty of body cancer!
Waiting for install: x-over steering, dual 'cases, twin-stick, 3" body & drivetrain lift, rear springs up front
Still need: rear springs, 35" MT's, bumpers/sliders
2001 F350 - 7.3 110k miles on WVO conversion now!
Re: Noisy Power Steering Pump [Re: airfooter] #351133 11/21/03 09:47 PM
kyle-22r Offline
it did it on my '79 for a while...turned out the fluid was leaking from my steering box. i'm planning on going to hy-steer so i just took the belt off the power steering pump to shut it up
check your fluid level, that's what usually causes the noise
'91 4x4 shortbed
22R-E, W56, the dd!
Re: Noisy Power Steering Pump [Re: airfooter] #351134 11/21/03 10:58 PM
gota87toy Offline
it's time to change the fluid to Synthetic ATF-
use a gear oil pump, (the ones that thread onto a quart bottle of 90W work well) pump the tank empty, refill, run the engine to circulate the new fluid, repeat until the fluid is clean. I used 2 quarts, one to flush with, one to refill w/ clean fluid. No more noise.
"Nine-11 changed me," he said. "I'm shocked that it didn't change the whole country, frankly."
Dennis Miller
Re: Noisy Power Steering Pump [Re: gota87toy] #351135 11/22/03 04:05 AM
kyle-22r Offline
an even easier way is to get a turkey baster(2 bucks max) and shove a 3" or 4" piece of surgical tubing on the end, so you can get all the way to the bottom of the reservoir, then do the procedure above
i'm not so sure if mine was leaking before or after i changed the fluid, but i remember later that day seeing the blood red goo on my springs
'91 4x4 shortbed
22R-E, W56, the dd!
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6024 MB (Peak: 0.6577 MB) Data Comp: Off Server Time: 2026-11-18 03:20:23 UTC
