Rear Leaf Spring
#355650
12/01/03 02:07 AM
Broke a left rear leaf on a 1997 tacoma 4x4. Will a set off a 2002 tacoma work under this truck? Thanks, Scott. --------------------------------------------------------- 1997 t-100 sr5,rs5000,31" buckshots
Re: Rear Leaf Spring
#355651
12/01/03 03:35 AM
I believe the 95.5 to 97 Tacomas used shorter leaf packs and that the 98 and newer Tacoma leaf packs won't fit. Could be wrong about that, though. I also remember reading a few posts on tacomaterritory.com that the 95 and older, non-Tacoma 4x4 leaf packs are a perfect fit for the 95.5 to 97 Tacoma 4x4s, but I don't know if they provide lift or retain the stock ride height.
Hope this helps.
Ed Q. 03 TRD Tacoma Ext Cab 3.4L 4x4 93 Ford Bronco 86 Ford Bronco 47 CJ2A Willys
[Re: EQuin]
#355652
12/03/03 03:20 AM
the 95.5 - 97 tacos are very bad for breaking the center leaf on the rear
you can either spend the bux on the stock springs or get a lift <img src="/forums/images/graemlins/smile.gif" alt="" />
#355653
12/04/03 10:24 PM
Later Taco spring will not work without a new front hanger. However, 90-95 truck spring will work. They will also give you about 1.5" of lift, so the front would definately need some lift as well.
#355654
12/04/03 10:40 PM
I broke a leaf in my 87 toy, what a PIA to replace those suckers. It may not be worth using poly. bushings. I stayed with the rubber ones.
good luck
#355655
12/07/03 09:36 PM
I read in this forum that the 1996 non TRD 4X4 Tacoma pickups had fewer leafs than the newer TRD Tacoma pickups. I checked out a TRD Tacoma pickup in the parking lot and it appeared to have the same number and thickness leafs, not sure about the length. I bought my 1996 4X4 XCab used so I do not no its history. What does the X on the tailgate mean? Does it simply mean that it is an extended cab XCab? Bottom line is I do not know if I have the better leaf spring setup or not?
Later Ron
1996 Toyota Tacoma XCab 4x4 3.4L ARB Bullbar & Warn Winch Super Spring progressive leaf springs SuperBumper in rear 2" receiver Moderator Marks factory Bilstein shocks/Front Coils Albuquerque, NM
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5997 MB (Peak: 0.6668 MB) Data Comp: Off Server Time: 2026-06-20 22:57:18 UTCValid HTML 5 and Valid CSS
