Question about '91 4Runner Rear ABS #355979 12/01/03 04:32 PM
distilled Offline OP
My '91 4Runner supposedly has Rear ABS.
Whenever I start it up the little Rear ABS light flashes on then turns off, which I assume means they are functioning...
How can I tell if the ABS is working?
I've never felt them pulsating, even when braking hard.
My brakes seem to lock up very easily in wet weather conditions.
Part of this is due to my very worn tires, but shouldn't I at least feel some sort of brake pedal pulsing or something if ABS is working and brakes are locking up?
1991 4Runner V6(3VZE) 5-Speed 4X4 SR5
349,000 Miles and STILL Running Strong!!!
Re: Question about '91 4Runner Rear ABS [Re: distilled] #355980 12/01/03 06:13 PM
Robinhood150 Offline
I was on a snow covered road a little while ago and I wanted to see if I can feel my abs so I slammed on my brakes. I barely felt the pulsing through the brake pedal. So, it's actually pretty hard to feel it but I'm pretty sure it's working. You might be hearing the fronts lock up.
Steve
My Website ||Gettin' off 4wheel drive club member
'93 4Runner V6 4x4 auto tranny
If you have to ask about a SAS, you're not ready for it.
Re: Question about '91 4Runner Rear ABS [Re: distilled] #355981 12/02/03 03:47 AM
ldivinag Offline
on mine, you can feel that sucker working.
remember, it works ONLY while you are in 2wd. once you shift into 4wd, it is disabled.
also, check your prop valve level in the rear axle, it could out of "alignment" so your fronts are locking up without the rears ABS'ing...
also, it's only for the REAR wheels... not the fronts...
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: Question about '91 4Runner Rear ABS [Re: ldivinag] #355982 12/02/03 07:59 AM
code33 Offline
I've felt the pulsation in 4wd on a snow covered road and in the dirt before. I don't believe that the system turns off but it is the 4wd that prevents it from working.
That was before it was permanently disabled.... <img src="/forums/images/graemlins/smile.gif" alt="" />
Classifieds & Suzuki Moderator
Re: Question about '91 4Runner Rear ABS [Re: distilled] #355983 12/03/03 01:15 AM
Yep the little light coming on then going off when you start the motor is supposed to mean that the ABS is functioning.
Here in Phoenix it doesn't get too slippery so mine is unplugged. Come to think of it I was fine at the Snowbowl in Flagstaff last winter. If the `91 and `94 systems are the same then the online `94 FSM should have a complete system checkout procedure. I don't have the link for the FSM handy but you should find it on this board or yota. Good luck.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6062 MB (Peak: 0.6708 MB) Data Comp: Off Server Time: 2026-06-07 04:46:30 UTC
