16x8 and 285's, what backspacing? #356936 12/03/03 01:44 AM
dragr1 Offline OP
I'm contemplating getting 16x8 wheels and 285's and staying with the stock a-arms or getting factory 16x7's with 285's and ATS (Inland) a-arms.
What backspacing should I get with the 16x8's to avoid rubbing the factory a-arm and/or fender?
Here is what I have for suspension:
front: OME 882's, OME HD shocks, one trim packer
rear: OME HD coils and shocks
I also have an ARB Prado bar, Warn M8000, and Trailcarnage skidplates holding that front end down with the 882's.
Opinions? 16x8's and stock a-arms or
16x7 factory and Inland a-arms
1985 Toyota 4Runner, dual e-lockers, exo and more
2007 Toyota Tacoma Crewcab TRD 4x4
2000 Suburban 2500 4x4
1991 Tiffin Allegro Class A MHome (Ole Krusty)
Re: 16x8 and 285's, what backspacing? [Re: dragr1] #356937 12/03/03 01:48 AM
Darren Offline
4.25 or 4" would be optimal.
I rub substantially more with 8" wheels than I did with the OEM 7's with 285's. You'll have to grind down the pinch weld/body seams behind the plastic fender liner a bit in front. I don't think there's any way around it.
I gained quite a bit more room next to the upper A-arm, so that is no longer an issue.
2002 4Runner
MyColorado.org (CO landscapes, destinations & trail reports)
Re: 16x8 and 285's, what backspacing? [Re: Darren] #356938 12/03/03 02:03 AM
dragr1 Offline OP
I went to your website, those 16x8 Mickey T's look great! It says you have 4 9/16 backspacing? So, 4" would tuck the wheels farther in the wheelwells? Just trying to make sure b/c I'm not after that "skateboard" look.
Re: 16x8 and 285's, what backspacing? [Re: dragr1] #356939 12/03/03 02:21 AM
Darren Offline
Thanks!
4" would push the wheels out further. I basically have 4.25" in the front with those spacers, and it is just a fraction away from the calipers.
2002 4Runner
Re: 16x8 and 285's, what backspacing? [Re: Darren] #356940 12/03/03 02:25 AM
dragr1 Offline OP
Thanks!
Ok, 4.25 is farther out, I saw some wheels with 3.75". I'll definitely stay away from 3.75" and shoot for 4.25".
Thanks.
Re: 16x8 and 285's, what backspacing? [Re: dragr1] #356941 12/03/03 02:31 AM
Darren Offline
No, I meant 4" is further out than 4 9/16". The smaller the number, the further out your wheel is.
2002 4Runner
Re: 16x8 and 285's, what backspacing? [Re: Darren] #356942 12/03/03 02:35 AM
Jeff the marmot Offline
Hey Darren I was wondering which backspacing you ultimately went with. So you ended up with 4 9/16" minus a 1/4" spacer?
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
Re: 16x8 and 285's, what backspacing? [Re: Jeff the marmot] #356943 12/03/03 02:45 AM
Darren Offline
Yes, that's correct. It was a custom spacer Andy (Red Chili) over here in Aurora designed and has worked for him.
2002 4Runner
Re: 16x8 and 285's, what backspacing? [Re: Darren] #356944 12/03/03 04:20 AM
dragr1 Offline OP
Yeah, that's what I meant. I don't want them to stick out any farther than necessary. I like the tires being inside the fenderwells. Thanks again.
Re: 16x8 and 285's, what backspacing? [Re: dragr1] #356945 12/03/03 05:29 AM
Darren Offline
Okay, very good. Not sure if you saw this picture, but here is how mine fit under the flares:
Looks a lot better than with the 7" wheels filling out that area. They sit just a fraction outside of them. I'm not sure what type of flares you have, but anything smaller than the "limited" ones, they will definitely stick out further than the flare.
2002 4Runner
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6464 MB (Peak: 0.7663 MB) Data Comp: Off Server Time: 2026-05-29 15:21:26 UTC
