head conversion #357419 12/03/03 07:52 PM
doc long Offline OP
has anyone seen this?
http://cgi.ebay.com/ebaymotors/ws/e...p;category=33617&item=2444942572
seems like a good deal.
any pro or cons any body can think of?
Brian <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: head conversion [Re: doc long] #357420 12/04/03 05:27 AM
BoggerCJ7 Offline
I bought my rebuilt 4.0 head from them. I live in Clearwater, FL and went to their shop to pick it up. The head that you are looking at was not an option when I bought mine from them. I had to JB weld the water jackets. They're really nice guys and do quality work. They'll even take in your 258 head as a core. I love the conversion but am going to a 4.0 now. The reason is because I want fuel injection and the head added so much power that it ran down my tired 258 block, so keep that into consideration. I also added a weber and was very impressed with the overall results. Just keep in mind that this will cost a decent amount to do and if you retain your carb (which I did) then I would price match a fuel injection swap too. If I had to do all over again I would have gone straight to a 4.0. With that in mind $350 for a bolt in 4.0 head (conversion) it's not a bad deal at all. Just my 2 cents.........
Chris
1983 CJ7 with 1.21 giga-watts and a supercharged flux-capacitor
Re: head conversion [Re: BoggerCJ7] #357421 12/04/03 01:22 PM
doc long Offline OP
hey Chris,
thanks for the info. my 258 was rebuilt about 30k ago and i did the howell tbi over the summer. it runs really well now but i'm always looking for more stuff. did you use a 4.0 header or exhaust manifold? were there any problems or was it just a matter of making the exhaust work?
Re: head conversion [Re: doc long] #357422 12/04/03 01:47 PM
bogger when you say "fuel injection" do you mean TBI or TPI?
Re: head conversion [Re: doc long] #357423 12/04/03 05:19 PM
BoggerCJ7 Offline
<img src="/forums/images/graemlins/smile.gif" alt="" />OC:
I would say definately go for the head conversion it will add a lot of noticable horsepower. To do it this is what you will need.
-4.0 head
-4.0 Valve cover (1986 & newer 258 covers will work)
-4.0 header (exhaust manifold) I used a factory manifold with the expansion packs from a 96 cherokee.
-Spacer washers, I will explain these
-Some fab work........
Concernig the exhaust, all you will need to do is bring it to an exhaust shop and have them connect the pipe to the new manifold. They are different sizes, the 4.0 manifold's outlet is smaller than the 258's.
The intake is a little tricky. The 4.0 intake & exhaust ports are at the same level (unlike the 258) so your allignment holes on the intake will not work. What I did was notch out a little groove underneath the holes (on the intake) and sat the intake on top of the alignment pins on the 4.0 head.
Now come the washers. The space between the intake and exhaust will be further apart and you will have to buy or fab up some washers that are large enough to hold down both to the head.
Lastly, remember when you put the intake on top of the alignment holes on the head? This means the entire intake is sitting up higher now. Your top power steering bolt that bolts to the intake will not line up and what I did was cut out the top part of the bracket & used a washer to unite them again. One more thing on this, make sure that your TBI set-up will not interfere (SP?) with your brake master cylinder. I found this out the hard way when in 4-low trying to pull a buddy out and when reversing the torqued engine threw the throttle linkage into the BMC and wouldn't stop.........I had to turn off the engine to avoid running into my buddies wrangler. Or maybe my CJ just wanted to finish off my buds crippled YJ????????? <img src="/forums/images/graemlins/nana.gif" alt="" />
Probably not the best instructions but if you want some pics I'll see if I can borrow a friends digital and send them to you. Let me know.
:ODDBALL:
Neither, I mean MPI. I was at the junk yard a few weeks back looking for a pair of acout axles and then a 1993 Cherokee plopped right in front of me with a 4.0 in it. I got the whole engine, front accessories, wiring, & computer for $200.00. Not a bad deal. I was originally intending to rebuild my 258 and just use the fuel injection (MPI) off of the newly acquired motor but when I broke down the 4.0 to its block I found that this engine was in prestigne shape. I have now decided to just do an overhaul on the 4.0 and put it in. Keep in mind that if I had the money I would do my first option of keeping the 258 with 4.0 head and MPI but I don't think my school's tuition can be paid for in I-OWE-U'S <img src="/forums/images/graemlins/cheers.gif" alt="" />
Please ask any other ?'s because I sure had a lot when doing this.
Chris
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6112 MB (Peak: 0.6878 MB) Data Comp: Off Server Time: 2026-11-18 22:09:52 UTC
