Page 4 of 8 1 2 3 4 5 6 7 8
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: JohnnyBfromPeoria] #362368 08/17/11 05:42 AM
mxmikie Offline
Well it sounds like something to really (not) consider if, as it sounds, there's no discernable difference between having this system function or having it completely removed and disabled. I'll likely remove the whole plenum assembly when I replace my plugs, wires and coils, rather than take it apart to replace the lower plenum, then. Mine's safely taken care of.
Just to be clear, though, for those of you that have had the system both functional and not, there was no difference in low to middle torque? No difference in mileage?
i did not see any
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: mxmikie] #362369 08/17/11 06:11 AM
xFezx Offline
My father taught me to think, then why did they put it in there and how much did it cost them? <img src="/forums/images/graemlins/confused.gif" alt="" />
You can call me Fez
'95 SR 15x8 steel rims w/ 33x12.5 Duratracs, cranked torsion bars, "Baja" lights
'09 Nissan Sentra SR
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: JohnnyBfromPeoria] #362370 08/17/11 07:25 AM
StockRaider Offline
I believe OldColt said he did notice a difference when towing he said it felt like it could of used more torque. For me, my 3.5 doesn't seem to have a problem, but I will just replace the worn out bushings regardless.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: xFezx] #362371 08/17/11 12:26 PM
mxmikie Offline
i remember that statement...... when they made the vega <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: mxmikie] #362372 08/17/11 02:29 PM
Kevin C Offline
And some people cant notice if they have a dead cylinder, bad brakes or a slipping transmission.
Same goes for the balance shaft eliminators. Some dont notice a difference, others do.
I remember doing a test drive and mentioning to the owner that he had no rear brakes. He was sure I was kidding, because to him his car seemed just fine. After he got them fixed he still didnt notice the improvement.
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: Kevin C] #362373 08/17/11 05:43 PM
mxmikie Offline
kinda like women .... you know how you think you got a good one.....or kinda like the guy that is telling you how to date women but he is always alone ..... or the guy that tells you how crummy your harley is but he is always walking......
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: Kevin C] #362374 08/18/11 03:23 AM
sasnydley Offline
just have him stop on some wet Icy road....
I changed out my lower intake. Was About 400 total for parts. And the rare occasion I get the truck over 3000RPMs I think you can really feel it. Plus mine had such bad air leaks it ran like crap. Plus now I don't worry about some lil loose nut/screw ripping through my motor. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: sasnydley] #362375 08/18/11 12:28 PM
I could feel the difference when mine changed over, but my butt is edjicated. I can feel no balance shafts, too... <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: fasteddy] #362376 08/18/11 11:16 PM
ryany Offline
When I was a Nissan Service Advisor, I once had the Nissan Factory Rep tell me "Parts that the manufacturer doesn't put on a car don't cost anything to manufacture, engineer, or install, they never have to be stocked by the parts department, and they never cause warranty repairs."
While I do occasionally question the common sense of the Mitsubishi engineers, I don't question their abilities. I'm fairly certain that if the variable intake system didn't provide a benefit to the way the engine ran, they wouldn't have produced it.
95 Montero SR
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: ryany] #362377 09/18/11 10:59 PM
SeerAtlas Offline
wow, was searching to find everything I could on the butterfly and found this thread. Was wondering who started it back in 03, and I'll be damned, it was ME smile rflmao. So here i am, almost 9 years later, with a new SR, asking the same dam questions, jeez I must be getting old...didn't recognize myself as 'anonymous' till I saw the 'seer' sig LOL.
what a crackup. helluva board tho, missed you guys.
seer
89LS,90LS,91LS,91LS,95SR,89JeepGrandWagoneer,90JGW,91JGW,92JGW,93RangeRoverLWB,93RRLWB,94RRLWB,94RRLWB,95RRSWB; 90'Dodgezilla' 1-Ton Cummins4x4.
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.011s) Memory: 0.6441 MB (Peak: 0.7703 MB) Data Comp: Off Server Time: 2026-07-14 19:26:01 UTC
