Page 6 of 8 1 2 3 4 5 6 7 8
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: JohnnyBfromPeoria] #362388 09/27/11 02:47 AM
Kevin C Offline
I'm sure if the bushings are very worn and allow leakage between the runners for differant cylinders, as well as around the butterflies then the gain from the dual tuned system will drop off.
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: mxmikie] #362389 09/28/11 01:14 AM
ryany Offline
i have 2 trucks with and 2 without the butterflys
Are your trucks are mechanically identical in all ways (identical wheels/tires, exhaust systems, age, mileage, equipment, etc) so you are comparing apples to apples?
95 Montero SR
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: Kevin C] #362390 09/28/11 01:18 AM
TheViper Offline
so i finally figured out which hose you disconnect, the one that goes to the vacuum actuator...my question is what did you guys plug the vacuum actuator with?
Also, so i understand correctly, you will hear lots of rattling at the front of the intake manifold area if the butterlys are loose?
1995 Montero SR
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: ryany] #362391 09/28/11 01:58 AM
mxmikie Offline
yes they are IROC montero's built by the same person with the same parts with the same wrenches ..... on the same day of the week .......... stepford montero's
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: mxmikie] #362392 09/28/11 03:46 AM
hazy_daze Offline
Did they all have a new hose from the fuel pump to the outlet pipe? I've been told that's a common problem...
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: hazy_daze] #362393 09/28/11 05:31 AM
mxmikie Offline
stainless braided urethane
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: TheViper] #362394 10/04/11 05:06 PM
Djbenny Offline
Alright regarding the Intake Manifold Butterfly valves, has anyone used an intake Manifold off a VR4 motor instead of our intake manifold and just bypass the butterfly valves all together? They should bolt up, even that little exhaust pipe to the manifold. The only thing is the throttle body would be facing the front rather that the side... Also the Manifold off a Sebring might work it looks similar as well but the throttle body would face straight to the firewall and i don't thing there would be enough room facing that way since our fire wall is so close to the motor. Any thoughts?
95 Montero SR 3.5L on 33x10.5 BFG A/T's, Cranked TBars, Stock Rear Locker
2001 Impreza 2.5RS Coupe, WRX Swap, 300HP!
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: Djbenny] #362395 10/04/11 09:18 PM
mxmikie Offline
so try both of them then you can let us know
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: mxmikie] #362396 10/05/11 01:16 AM
Djbenny Offline
That is just a photo i found on the internet. They do not belong to me. Thats why i asked the question because i wont go out of my way to purchase them unless someone has tried it before.
Re: 95SR 3.5DOHC acquired.Disconnect Butterfly? [Re: Djbenny] #362397 10/05/11 01:42 AM
I'll qualify what I'm about to say by stating that the Space Shuttle was made of over a million parts, all of them made by the lowest bidder.
My plenum is in the hands of a machine shop that made parts for the Space Shuttles. They said it would be no problem to make durable, non-binding and fairly tight bushings for the unit. We'll see...
My brother knows the owner from them both being parents of kids on a soccer team. My bro is an aeronautical/astronautical engineer by education, so it took me a while to explain it to him. Kidding.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6464 MB (Peak: 0.7717 MB) Data Comp: Off Server Time: 2026-06-10 00:07:55 UTC
