NO HEAT in 92 Cherokee #363646 12/15/03 11:23 AM
comp Offline OP
son-inlaw has no heat i changed thermo. just because, the
heater control valve is moveing when switched(vac.) i have
switched man. till my hand went numb. nothing do these cores
clog up easy i know it was driven a few months with h20 only
<img src="/forums/images/graemlins/bird.gif" alt="" /> i drained it out and stained concrete. at the time it
was flushed but not with any real pressure or back flushed
any help <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: NO HEAT in 92 Cherokee [Re: comp] #363647 12/16/03 03:07 AM
Why not just get one of the heaters from like quadratec or 4 WD hardware that plug into the cigarette lighter, I'ver heard pretty good things about those.
Re: NO HEAT in 92 Cherokee #363648 12/16/03 06:08 AM
comp Offline OP
my grandbaby's only 16 months old she kinda' like's a little
heat, heck if i get warm air out to won't be to bad it's
only in the high 20's low 30's here <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: NO HEAT in 92 Cherokee [Re: comp] #363649 12/18/03 01:03 AM
Check out those mojave heaters I've heard they can heat a whole jeep up with a soft top on
Re: NO HEAT in 92 Cherokee #363650 12/18/03 01:33 AM
just replace the heater core. they do clog easily, especially when those "stop-leak" products are used, about $80 new, can get a used one at a scrap yard for way less with no promises
Re: NO HEAT in 92 Cherokee #363651 12/18/03 02:36 AM
comp Offline OP
ok goint have to back flush and blow out sat. 20-30 deg.
forcast <img src="/forums/images/graemlins/shocked.gif" alt="" /> have you had any problems with the insides coming apart on the vac.heater valve???
Re: NO HEAT in 92 Cherokee [Re: comp] #363652 12/19/03 05:42 AM
comp Offline OP
nobody ever had a heatercontrol valve go bad? (vac.underhood) never torn one apart!
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6088 MB (Peak: 0.6811 MB) Data Comp: Off Server Time: 2026-11-16 08:32:06 UTC
