NO HEAT in 92 Cherokee
#363646
12/15/03 11:23 AM
son-inlaw has no heat i changed thermo. just because, the heater control valve is moveing when switched(vac.) i have switched man. till my hand went numb. nothing do these cores clog up easy i know it was driven a few months with h20 only <img src="/forums/images/graemlins/bird.gif" alt="" /> i drained it out and stained concrete. at the time it was flushed but not with any real pressure or back flushed any help <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: NO HEAT in 92 Cherokee
[Re: comp]
#363647
12/16/03 03:07 AM
Why not just get one of the heaters from like quadratec or 4 WD hardware that plug into the cigarette lighter, I'ver heard pretty good things about those.
#363648
12/16/03 06:08 AM
my grandbaby's only 16 months old she kinda' like's a little heat, heck if i get warm air out to won't be to bad it's only in the high 20's low 30's here <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
[Re: comp]
#363649
12/18/03 01:03 AM
Check out those mojave heaters I've heard they can heat a whole jeep up with a soft top on
#363650
12/18/03 01:33 AM
just replace the heater core. they do clog easily, especially when those "stop-leak" products are used, about $80 new, can get a used one at a scrap yard for way less with no promises
#363651
12/18/03 02:36 AM
ok goint have to back flush and blow out sat. 20-30 deg. forcast <img src="/forums/images/graemlins/shocked.gif" alt="" /> have you had any problems with the insides coming apart on the vac.heater valve???
[Re: comp]
#363652
12/19/03 05:42 AM
nobody ever had a heatercontrol valve go bad? (vac.underhood) never torn one apart!
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6076 MB (Peak: 0.6799 MB) Data Comp: Off Server Time: 2026-11-04 14:03:54 UTCValid HTML 5 and Valid CSS
