22re bog #364764 12/17/03 03:43 AM
N
nader454 Offline OP
Hello, new to the board, hope this rings a bell with someone. I have an 89 22re 5-speed. It bogs heavily for a few seconds then wakes up. At first, it was only on damp or rainy days, now its everyday. I've replaced common tune-up parts including cap, rotor, plugs, wires, fuel filter. It lays down on power, not really a dead miss. No check engine light or codes, so I'm leaning more to something simple overlooked. Thanks for your time.
Re: 22re bog [Re: nader454] #364765 12/17/03 04:28 AM
did u change your airfilter
Re: 22re bog #364766 12/17/03 04:41 AM
N
nader454 Offline OP
Cleaned it.(K&N)
Re: 22re bog [Re: nader454] #364767 12/17/03 04:48 AM
try changing your oxegen censor
Re: 22re bog [Re: nader454] #364768 12/17/03 05:08 AM
Johnboy Offline
Hmmm sounds electrical, make sure water hasn't gotten to your computer. I'd start by getting under the hood while it's doing it's missing thing and wiggle all the wires you can get your hands on. Sounds stupid but it uncovers lots of over looked problems. Check for vacuum leaks while you're in there, just in case
-John
85 4Runner, 4" lift, bumpers, sliders, locker
Re: 22re bog [Re: nader454] #364769 12/17/03 08:45 AM
Ben894x4 Offline
Also might try cleaning the throttle plate and intake with sensor safe carb cleaner and a (old) toothbrush. If this doesn't help, also could be the egr valve which can be removed relatively easily and cleaned out.
89 xcab 4x4 22re. 1.5" BJ spacers, 3" shackle and AAL + fender trim. 33x12.5 R15 MT/Rs, 15x10 rockcrawler streetlocks. 488 yukons by ZUK, detroit rear and true-trac front. 2 1/4" cat-back exhaust. Redline gear oil. Rear bumper by bentup.com.
Re: 22re bog [Re: nader454] #364770 12/17/03 01:10 PM
foxtrapper Offline
A usefull diagnostic tool for this sort of condition is a dark and damp night. With no lights on, open the hood and start the engine. Then just look at it. Give yourself a few minutes for your eyes to adjust. Many times you will then find a pronounced electrical arcing that was not visible in daylight.
'97 T-100 SR5
Re: 22re bog [Re: foxtrapper] #364771 12/18/03 02:44 AM
N
nader454 Offline OP
Thanks guys, I'll try these suggustions.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6152 MB (Peak: 0.6959 MB) Data Comp: Off Server Time: 2026-06-21 22:36:12 UTC
