split fire plugs? #365389 12/18/03 04:41 AM
I was wondering if anyone had tried split fire plugs and had good luck with them. Im hesitating because i didnt know if they ran to hot for the 2.6. If anyone has any info it would be much appreciated.
Re: split fire plugs? #365390 12/18/03 05:06 AM
strawmyers Offline
Isuzu Moderator
IMHO the best plugs you can put in a 2.6 are NGK, wouldn't worry about any other type.
BTW, you have seen this haven't you?
Sean Strawmyer
Re: split fire plugs? #365391 12/18/03 05:45 AM
Sword King Offline
I found them cheap at K-mart and have had them in my 2.3L 4ZD1 for about 10K without any problems. Nothing like what people complain about in platinum Bosch plugs. Nothing great either.
2x '88 2.6L Troopers (one for parts)
'86 2.3L Trooper
'99 Acura SLX
Re: split fire plugs? [Re: Sword King] #365392 12/18/03 06:00 AM
Jim_Paget Offline
You might want to do a Google search on +"federal trade commission" + splitfire.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: split fire plugs? [Re: Jim_Paget] #365393 12/18/03 06:12 AM
I never understood the concept of splitfires. Electricity follows the path of least resistance, right? So how could it arc out at two seperate electrodes unless each provided exactly the same value to ground? Even if they did work as advertised your still distributing the same amount of spark energy across a larger area, resulting in a larger but weaker flame kernel.
Re: split fire plugs? #365394 12/18/03 09:05 AM
mlclark Offline
Isuzu Moderator
It doesn't.
After they got in trouble with the FTC, the second arc was removed from their advertising. They may show it flickering between the two in some ads, but the print ads had one arc removed.
Michael
Re: split fire plugs? [Re: mlclark] #365395 12/18/03 02:28 PM
TurdBuggy Offline
The Splitfires may be a decent performing plug, but they are deceptively advertised. Most reputable mechanics will advise against using them, simply because the company has duped the buying public into believing the split electrode will give them a performance advantage, when it certainly will not.
Re: split fire plugs? #365396 12/18/03 04:34 PM
Dont bother with split fires, or platinum fours, or any other of those high performance plugs. If you want to go all out, get NGK plugs and wires. They are made specificaly for each vehicle or group of vehicles, and are the best performance bang for your buck. If you have to go buy spendy plugs buy the high performance NGK iridium's.
Re: split fire plugs? #365397 12/18/03 04:55 PM
The only possible advantage I ever saw was that they might advertise them as longer lasting. As one electrode got dirty/worn it would arc to the other and back again through out the life cycle of the plug. I've heard, and it makes sense to me, that plat 4's are even worse, as the flame kernel is actually shrouded by all the electrodes surrounding it. I've used NGK for years with no problems.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6181 MB (Peak: 0.7044 MB) Data Comp: Off Server Time: 2026-11-01 18:52:49 UTC
