YJ Springs on A CJ #365404 12/18/03 05:26 AM
mwhite Offline OP
I am going to install lift kit om my 83 Cj7. I would like to
use yj springs for a little better ride.
Is it correct that all I need to do for the front spring
hangers is unbolt and add either rear or front hangers
from a yj. I know I have to relocate hangers farther
forward as per nutter's tech article. buy yj front shackles.
Thanks Mike
88 Mighty Max 2.6 (170,000miles)
3 body lift, 1 1/2 torsion lift, lower bumpstops, 4.625
gears, 31 1/2 buckshot radials,warn 8274
Re: YJ Springs on A CJ [Re: mwhite] #365405 12/18/03 08:49 AM
valleycat Offline
what type of lift? i don't think the spring rates would be different on an aftermarket kit between a cj and yj. where does ride quality come in to the equation? the yj springs are slightly longer but i don't think that would make much of a difference in ride. is it soa w/stock yj springs?
Re: YJ Springs on A CJ [Re: mwhite] #365406 12/18/03 03:19 PM
Mwhite, the front YJ springs are wider then the stock CJ springs, which is the reason for the new hangers and shackles. IÆve done a bit of tinkering with my 82 to get it lifted and riding better and can tell you that IÆm not totally convinced that YJ springs will give you that much better of a ride but IÆll add that any degree of ride quality (even a little) is worth doing on these old rigs.
There are a few factors to consider here.
Spring rate is spring rate. You can get a CJ spring that is rated as light as a YJ spring which means that you wonÆt notice a difference in the amount of give between the CJ and YJ springs. Where the difference isà. is in the length and in the flex. The YJ spring is longer and will therefore give you a better ride. It also will flex better and therefore give you better articulation when going over things. You havenÆt said what kind of lift your considering so IÆll through in a cautionà. DONöT DO A SHACKEL LIFT. A shackle lift will screw up your steering and put you at risk of a role over. A Spring Over or Shackle Reversal is the only way to go.
Re: YJ Springs on A CJ [Re: mwhite] #365407 12/18/03 04:15 PM
What's wrong with an aftermarket leaf lift? That's where you'll get your better ride. Skyjacker being about the softest, BDS is probably your best value and ride for the buck www.bds-suspension.com and an excellent guarantee. A lot less work and a lot better ride. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: YJ Springs on A CJ #365408 12/18/03 10:47 PM
IMHO, Reverb has good technical info, and Rit has a great idea. Don't bother with the YJ springs. You can get lighter and smoother in the original size for not so much green.
Re: YJ Springs on A CJ [Re: mwhite] #365409 12/19/03 10:17 PM
Junkie Offline
I would go with the Rubicon Express 4.5" Kit. Just installed one on my 86' and it rides better w. 39.5" Swampers than it did stock. The kit is about $950, but in my opion well worth the cash. It comes with everything. Wider front Springs (2.5" wide), spring skid plates, shakles, quick disconnects, drop ptman arm, greaseable bushings, extended brake lines, all necesaary hardware. By far the best bolt on suspsion for a CJ. I have used every kit (Skyjacker, Pro Comp, Rancho, Black Diamond) and this kit puts all these are "So called" kits to shame. I would recommend this kit to everyone and I would buy it again no doubt about it. Again, the most complete kit on the market period, easy bolt on w/ wider springs & the I can't say enough about how great it rides.
1986 CJ7, rebuilt 258, T176, Dana 300, 4.5 Rubicon Express Lift, 3" Body Lift, Currie 9", Dana 44 (on it's way), 40" Swampers
Re: YJ Springs on A CJ [Re: Junkie] #365410 12/20/03 01:33 AM
mwhite Offline OP
Thanks for all the info. I think I will check out the
rubicon lift.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6148 MB (Peak: 0.6895 MB) Data Comp: Off Server Time: 2026-11-16 01:19:47 UTC
