Page 1 of 3 1 2 3
Power Antenna Modifications, the quest of knowledge #365585 12/18/03 08:16 PM
Sargent 'D' Offline OP
Hi, I purchased this switch to put in my 4 Runner to be able to put my power antenna up and down while 4 wheeling, or using an aftermarket CD changer without the power antenna going/being up. I thought it would only have a few leads on it that I would have to trouble shoot, but it turns out it has 6. The switch controls the antenna and is also lights up with the interior lights are on at night. Anyone know enough about this to be dangerous? Can you please help me lable my graphics so I can put this thing in?
Thanks!
Re: Power Antenna Modifications, the quest of knowledge [Re: Sargent 'D'] #365586 12/18/03 09:32 PM
fourwd1 Offline
If I had the switch and an ohmmeter I could tell you, but I can't tell too much from the pic. Sorry
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: Power Antenna Modifications, the quest of knowledge [Re: Sargent 'D'] #365587 12/18/03 09:59 PM
id get out your contanuity tester and see start with one termanal turn on the switch and see which terminal has power
id say the 2 out side control one the inside mite be light and 2 middle ones the other switch
Re: Power Antenna Modifications, the quest of knowledge [Re: Sargent 'D'] #365588 12/19/03 04:49 AM
ldivinag Offline
you really dont need that complicated switch.
you just cut the power going from the head unit to the power antenna and that lowers it...
so a SPST switch outta do it...
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: Power Antenna Modifications, the quest of knowledge [Re: Sargent 'D'] #365589 12/19/03 05:50 AM
hilux_1990 Offline
...ah yes, but the factory switch looks cool <img src="/forums/images/graemlins/smile.gif" alt="" />
Is this the Landcruiser switch Sarg? and do you have the part number for it please?
Now to get your antenna working... as has been suggested, you'll need a multimeter to check the pinouts on the switch. I would suggest removing the little globe (so you have access to the globe contacts) and working out which pins are for the light. Then, with the globe still removed, work out which pins are for each switch. The reason I would remove the globe is that they are often connected to a 'common' point with the switch contacts and your multimeter will therefore give you 'false' readings as it will register continuity through the globe.
Did you draw that diagram yourself? if the switch is from a Landcruiser, someone over in the 'cruiser forum with a Factory Service Manual should have the pinouts for it.
1990 HiLux Xtra-Cab
Re: Power Antenna Modifications, the quest of knowledge [Re: hilux_1990] #365590 12/19/03 10:02 AM
Thanks for the info guys.
Yep, drew it myself from what I could see, and the switch is for a Landcruiser.
The part number is: 84760-60030. I got it for about $52.00. I mail ordered them from Daytona Toyota in Florida through Steve Dionne. Thought 52 was a pretty good price since everywhere else was quoting me 70+ bucks. Once I get all the leads figured out, I'll lable them, and publish them here.
Re: Power Antenna Modifications, the quest of knowledge [Re: Sargent 'D'] #365591 12/19/03 04:56 PM
Ok, assuming left to right is 1-6.
When Up is pressed:
1-2 Open
1-3 Open
1-4 Open
1-5 Open
1-6 Shorts
2-3 Shorts
4-5 Shorts
When Down is pressed:
1-6 Shorts
2-5 Shorts
3-4 Shorts
Nothing Pressed
1-6 Shorts
2-4 Shorts
2-5 Shorts
4-5 Shorts
Ok all you electricians, What does it all mean?
Re: Power Antenna Modifications, the quest of knowledge [Re: Sargent 'D'] #365592 12/19/03 05:54 PM
hilux_1990 Offline
I think it's important you work out what pins are connected to the light globe.
If you unscrew the globe you will be able to see the contacts inside the hole. Connect your meter between each of the globe contacts while checking for continuity with each of the six pins.
As mention before, leave the globe out so it doesn't cause any 'problems' while you check all the pins.
1990 HiLux Xtra-Cab
Re: Power Antenna Modifications, the quest of knowledge [Re: Sargent 'D'] #365593 12/19/03 06:22 PM
hilux_1990 Offline
As for what you've checked so far, all I could work out is that pins 1 & 6 are probably for the light.
Also, according to your diagram, pins 2 & 3 are joined together anyway so they can be treated as a single connection.
The fact that pins 2/3, 4 & 5 are all 'shorted' when nothing is pressed had me stuck.
1990 HiLux Xtra-Cab
Re: Power Antenna Modifications, the quest of knowledge [Re: Sargent 'D'] #365594 12/19/03 06:35 PM
TOY4ICK Offline
If you let me know which year the switch is from, I can look up the wiring diagram and let you know which wires go where.
TOY4ICK
'86 4Runner SR5 - 22R-EB with V-6 Throttlebody, 2" 4Crawler B.L., Ball Joint Spacers, Rock SliderZ, TJ Coils, 5.29's, Rear Locker, 33" Duratracs
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.007s) Memory: 0.6383 MB (Peak: 0.7619 MB) Data Comp: Off Server Time: 2026-10-21 18:52:58 UTC
