ABS #366781 12/21/03 08:44 PM
Hey I would like to know if there is a way to disengage the abs while im up to no good in the Dessert. <img src="/forums/images/graemlins/rodent.gif" alt="" />
Bill
Re: ABS #366782 12/21/03 10:52 PM
MutinousDoug Offline
Bill;
Just pull the fuse. You'll get a light in the dash, but it's no brighter than your TOD light.
2001 Trooper stock hunting rig/canoe hauler and daily driver
Re: ABS #366783 12/21/03 10:57 PM
TrailMystic Offline
The fuse box for your model should be in the engine compartment on top of the wheel well on passenger side. There should be a fuse diagram on the top of the fuse box showing you which one is the ABS fuse. I take mine out all the time when I'm wheeling, and I put it back in when I air up and unlock the hubs.
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: ABS [Re: TrailMystic] #366784 12/21/03 11:59 PM
Thanks for the info.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5927 MB (Peak: 0.6512 MB) Data Comp: Off Server Time: 2026-06-07 00:27:23 UTC
