Rough idle, and no low end power #367684 12/23/03 03:55 PM
92Pickup Offline OP
I've got a '92 pickup with a 22re. The past couple of days it's been idling really rough, to the point of almost stalling. It also bogs down when acclerating till about mid way through the rpm range(just guessing because there's no tach) then it clears up and the top end pwoer is actually pretty good. I thought it might have been the plugs, wires, rotor and cap because they were pretty bad shape but that has not solved the problem. I'm woundering now if it might be the O2 sensor? Any other thought on what it could be?
Thanks
Adam
Re: Rough idle, and no low end power [Re: 92Pickup] #367685 12/23/03 08:06 PM
Esquire812 Offline
*could be a hanging EGR valve. Should be closed until around 2500 RPMs, if its letting any gases by prior to then the ECU cant compensate for it and the result is similar to a vaccum leak. Could always check that out by temporarily blocking the pipe to the back of the intake plenum. If it runs fine and idles strong while blocked off then you have found your problem. If thats not it, then you got a whole big can of worms you get to look forward to testing and checking.
Bad O2 sensor will usually drop fuel mileage considerably.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: Rough idle, and no low end power [Re: Esquire812] #367686 12/24/03 08:13 PM
92Pickup Offline OP
This may sound stupid but whats the intake plenum?
I'm just trouble shooting now.
Thanks
Re: Rough idle, and no low end power [Re: 92Pickup] #367687 12/24/03 09:10 PM
Esquire812 Offline
The plenum is the upper portion of the intake manifold that says EFI on it. In the front your air tube connects to the throttlebody which is bolted to the plenum, on the back side is where the EGR bolts to it with (2) 12mm bolts.
85' Sillyca 22R-Esq
Re: Rough idle, and no low end power [Re: Esquire812] #367688 12/24/03 11:30 PM
how long before O2 sensors usually go bad? and what could cause them to go bad prematurely?
Post deleted by little_joe #367689 12/24/03 11:45 PM
Re: Rough idle, and no low end power #367690 12/25/03 05:26 AM
ok thanks. looks like it might be time for a new O2 sensor.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6124 MB (Peak: 0.6908 MB) Data Comp: Off Server Time: 2026-06-17 00:33:10 UTC
