Amsoil Air Filter maintenance question #368138 12/24/03 02:42 PM
CDUFF7 Offline OP
Anyone reoil the Amsoil Air filter with regular oil or some substitute oil? Asking because I do not want to order over the net due to HazMat shipping.
Re: Amsoil Filter maintenance question [Re: CDUFF7] #368139 12/24/03 03:55 PM
CDUFF7 Offline OP
Was thinking of using 10W30.
Any inputs?
Re: Amsoil Filter maintenance question [Re: CDUFF7] #368140 12/24/03 04:15 PM
Red_Chili Offline
Toyota Section Staffer
I assume you mean the air filter? Not familiar at all with Amsoil filters, but with motorcycle foam air filters I have use No-Toil which works extremely well and is easy easy to clean up (water cleanup, no kidding. They supply a dry powdered detergent that makes water just eat the stuff up. Use gloves.). Its very tacky stuff, much more so than motor oil, and catches everything. You might find its not a hazmat material for shipping.
-Bill
Re: Amsoil Filter maintenance question [Re: Red_Chili] #368141 12/24/03 04:25 PM
CDUFF7 Offline OP
Thanks, I should have said "air" in the thread. I will go back to edit. Can the No-Toil Filter Oil be purchased online? I want to order some.
Re: Amsoil Air Filter maintenance question [Re: CDUFF7] #368142 12/24/03 04:33 PM
foxtrapper Offline
Air filter oils are sticky, which is good for trapping and holding dirt particles. Motor oils will work in a pinch, but aren't sticky. They don't have the same capture or holding power as filter oil.
Motorcycle shops should have filter oil, as will any auto shop carrying K&N filters.
'97 T-100 SR5
Re: Amsoil Air Filter maintenance question [Re: foxtrapper] #368143 12/24/03 04:43 PM
Red_Chili Offline
Looks like you have a distributor in Japan...
http://www.notoil.com/distframe.html
brought to you by www.google.com
Hey- thanks for your service!
-Bill
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6110 MB (Peak: 0.6805 MB) Data Comp: Off Server Time: 2026-11-16 01:17:06 UTC
