HELP !!!! Can anybody help me for radio wire color code for 99 Montero
#369110
12/27/03 05:14 AM
I install a aftermarket DVD player, However I am not sure if I connect the correct wires. Because when I accelerate there is interference noise happen. Or, there is something wrong with the application. Help me please.
Re: HELP !!!! Can anybody help me for radio wire color code for 99 Montero
[Re: dick0309]
#369111
12/27/03 05:49 AM
You probably need to ensure your power leads have an RF Choke (I think that's what they're called) on them to prevent this.
[Re: dick0309]
#369112
12/27/03 06:11 AM
If you are grounded properly you really shouldn't need an RF choke. 9/10 they are cover-ups for crappy wiring. Make sure you have a "clean" power lead, like one that doesn't already have 100 things on it, that is not crossing anything that could create interference. Ground wires should be 12" or less too, something to bear in mind.
Jon
[Re: dick0309]
#369113
12/27/03 07:30 AM
Also make sure that you keep speaker and power wires as far apart as possible.
I recently had interference in my system. Turned out one of the RCA's was bad so I just did a quick fix on it (wedged a folded legal size envelope between the RCA and antenna cable).
[Re: OTEP]
#369114
12/27/03 08:01 PM
thank you all. Will try to fix it this later. Thanks for your value information. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6043 MB (Peak: 0.6645 MB) Data Comp: Off Server Time: 2026-06-17 12:02:20 UTCValid HTML 5 and Valid CSS
