Page 1 of 3 1 2 3
Sizing up anti-seize #369203 12/27/03 09:23 AM
rumrunner Offline OP
I broke a couple bolts off while removing my skid plates recently and someone at the hardware store recommended anti-seize lube when replacing them. I just replaced the drive belts and used liquid wrench to loosen the bolts. I didn't like the idea of spraying that stuff all around the belts, so I'm wondering what the best way to deal with this would be.
Are there any situations where antiseize lube should not be used on threads? Torque sensitive parts?
Once you're in a too-late situation, will a breaker bar or impact wrench actually 'save' a bolt that would break under the force of a regular wrench, or do they only make removal easier?
1992 Mighty Max 4x4
3.0 5-speed
Herculined bed
Re: Sizing up anti-seize [Re: rumrunner] #369204 12/27/03 10:00 AM
DaphneD Offline
Well, I must confess that I'm an anti-seize junkie. I use the goop on every standard external bolt application I encounter. Follow the torque specs and there's an overwhelming chance that the bolt you used anti-seize on will NOT fall out. Siskel and whoever the new guy is give it two thumbs up! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Ever tasted it? On second thought, don't do that.
'89 Raider 3.0L V6 (6G72) w/ AW372L (A44DL) A/T
"The Millennium Falcon of automobiles"
Re: Sizing up anti-seize [Re: DaphneD] #369205 12/27/03 01:38 PM
I use antiseize wherever the fastener is subject to corrosion, and red label threadlocker (Loctite) on anything I don't want to lose off the truck.
A breaker bar or other extension won't keep a rusted bolt from breaking, but may give you a finer "touch" to keep from rounding it off or breaking the bolt. My best technique is to put the fastener under a strong torque short of rounding/breaking, and then whack it a good lick toshock it free, after a generous dose of PB Blaster, of course. A box end wrench makes whacking the head easier, and the slickest trick is to use an air hammer to do the shaking up....
Re: Sizing up anti-seize [Re: rumrunner] #369206 12/27/03 05:16 PM
bretwalda Offline
RR I dont know if your saying LiquidWrench is an anti-sieze? Maybe they call it that but I wouldnt use it as such. I think the stuff Doug's talking about and what I use is bought in sqeeze-tube form. I get the stuff made by that "Form-A-Gasket" brand and its usually found by the tubes of silicone gasket.
As far as a bolt-loosening spray I highly recommend PB Blaster - I have never not been able to remove a bolt with it. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
concreteprinter.com
Re: Sizing up anti-seize [Re: rumrunner] #369207 12/27/03 06:18 PM
Grandpa Bill Offline
Put me in the "I'm all for it" column on this one.
I've used anit-seize on all of the fasteners that are likely to get rusted, corroded, galled, burred, whatever in the hole. So far, I haven't had too bad of luck with anything (knock on wood).
I use it religiously on the spark plugs. I talked to several different "experts" from a friend (ASE technician) to two of the techs at a local dealer. The opinion that they all held was to use it. Also, another tip they gave me for the spark plugs is to remove them when the engine is stone cold. I had a problem one time with one to the plugs and tried this, it works! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Bill Mattson, Certified Old Guy
Monty-less (right now)
Laura Mattson, Certifiable
Get in, sit down, BUCKLE UP, shut up and HANG ON!!!
Re: Sizing up anti-seize [Re: rumrunner] #369208 12/27/03 06:22 PM
One other thing I forgot, I'm with Fasteddy on the PB Blaster. Haven't found ANYTHING better for that type of application. Seen that stuff work on a monkey wrench that had been rusted in one position for years. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Sizing up anti-seize [Re: Grandpa Bill] #369209 12/27/03 06:38 PM
DaphneD Offline
Gotta give super-props to the PB Blaster too. I've been using it to loosen everything that's stuck or rusted. Spray a little bit on my winch cable when it rains.
As for spark plugs, I might be starting a war here but...
I don't use the anti-seize there. I had my plugs foul up badly about a month ago, mostly because of fuel delivery problems, but at first I blamed the tiny amount of anti-seize I used on the plugs. I have a concern that the plugs won't be grounded as well if the threads are coated with anti-seize. But that's just my superstition.
Gotta give props to the PB Blaster! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Sizing up anti-seize [Re: Grandpa Bill] #369210 12/27/03 08:25 PM
Only my opinion here, but I agree on both of these. Any steel threads going into aluminum(like heads), should have anti-seize. Also, I've read that you never take spark plugs out of aluminum when they are hot. Something about the aluminum expanding when it's hot, & possibly messing up the threads when you re-tighten the plugs. Am I right about this, or very mis-informed? Enlighten me on this, please. TNT
Re: Sizing up anti-seize [Re: bretwalda] #369211 12/27/03 09:33 PM
No, I'm talking about two different things. I've been using Gunk Liquidwrench to free up rusted bolts. The stuff from the hardware store is Permatex anti-seize lubricant and came in a jar with a brush for application. I don't see anything on the jar about any copper content, as I've seen mentioned before.
Ideally, I'd like to not have to use the liquidwrench spray at all. It seems like anything not inside the 'cabin' is going to rust after a few years, so I'm wondering if i should just slap some lube on everything after I work with it. Apart from parts that would need threadlocker, it looks like a good idea. What's an example of something on a truck that would get loctite?
I'm not sure what to think about Doug's bad engine-mojo <img src="/forums/images/graemlins/confused.gif" alt="" /> Could there be different ingredients in various lubes that would cause a problem? Maybe only certain brands are blessed by the IC Pope? ;-)
1992 Mighty Max 4x4
3.0 5-speed
Herculined bed
Re: Sizing up anti-seize [Re: rumrunner] #369212 12/27/03 09:53 PM
NathanC Offline
The Permatex Anti-seize is good stuff. I used up a bottle of the stuff in the past year alone <img src="/forums/images/graemlins/smile.gif" alt="" />. Like I've said before, anti-seize is your best freind. It'll prevent future frustration. Definately use it on spark plugs, just use it very sparingly and keep it on the threads.
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.011s) Memory: 0.6429 MB (Peak: 0.7700 MB) Data Comp: Off Server Time: 2026-11-17 11:00:58 UTC
