vented rotor swap #31830 04/19/02 02:02 AM
Supra 4x4 Offline OP
I am working on getting my truck ready for GSMTR and thought I was going to replace the front brake pads. After getting the wheels off and the calipers off I saw that I needed new calipers. Great time for the vented rotor swap. All was going great until I went to put the pads on the 86 model rotors. With all of my research nobody ever mentioned the pad retainer pins need to be replaced with 86 model pins too. As soon as I saw that the old pins were too short I knew why but I hadnt heard anybody talk about it. Luckily a buddy that works at the local Toyota dealership had some and all is well. It truly was a bolt on project. I wont drive it for another couple of days and then I'll comment on the difference. One more thing you also have to use 86 model anti vibration springs on the pads.
85 4Runner, R151F, Marlins dual case, high steer,and frnt springs. Chevy rears, TJM bumper w/Ramsey winch, custom rear w/swing out tire carrier and rock rails. BudBuilt cross member w/ 2" drivetrain lift, 33" Boggers. 5:71 gears & F&R spool.
Re: vented rotor swap #31831 04/19/02 01:33 PM
My original pins were extremely bad that I ruined them when I tried to remove them from the caliper. But, I got loaded calipers, which came with new pins, springs, and pads.
Re: vented rotor swap #31832 04/19/02 02:26 PM
fourwd1 Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Supra 4x4:
<strong>I was going to replace the front brake pads. After getting the wheels off and the calipers off I saw that I needed new calipers. Great time for the vented rotor swap. All was going great until I went to put the pads on the 86 model rotors. With all of my research nobody ever mentioned the pad retainer pins need to be replaced with 86 model pins too. As soon as I saw that the old pins were too short I knew why but I hadnt heard anybody talk about it. Luckily a buddy that works at the local Toyota dealership had some and all is well. It truly was a bolt on project. I wont drive it for another couple of days and then I'll comment on the difference. One more thing you also have to use 86 model anti vibration springs on the pads.</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">I ran into the same problem, and no one had the correct pins. Parts stores would look it up and every time they would be old style short ones. Finally took some long shoulder 1/4" bolts and drilled them for cotter pins. Works great!
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: vented rotor swap #31833 04/20/02 04:54 AM
CAZ Offline
Toyota Moderator
Hey Spencer,
What day are you going to get to Tellico? I am thinking that I will show up on Tuesday sometime.
Lots-o-work to do before the trip! Headed to the junkyrd tomorrow morning to get some supplies ;-)
CAZ
Re: vented rotor swap #31834 04/20/02 05:01 AM
If my work doesnt stop me I plan to be there Wednesday. Where do you usually camp? What will you be driving?
Re: vented rotor swap #31835 04/20/02 05:03 AM
Finished the swap today and drove it a very short distance (busy day. The brakes feel great and it was a very straight forward swap/upgrade.
Re: vented rotor swap #31836 04/20/02 06:51 AM
CAZ Offline
Toyota Moderator
Hopefully we will be in the overflow campground - on the left as you go in to the main camp.
I'll be driving this -
<img src="http://home.4x4wire.com/caz/pictures/85%204runner/85runner.jpg" alt="" />
Might look a little different by then, but it will still be black anyhow....
Re: vented rotor swap #31837 04/23/02 05:28 AM
Paul Elbisser Offline
Caz, did you put a Supra in that too?
I am still not sure when I plan to be there. Some of ROTR plan to leave on the 11th. Camping near Green Cove.
Paul Elbisser #3233
pastTLCAEastern Rep.
Pres Rice on the Rocks
www.riceontherocks.org
Re: vented rotor swap #31838 04/22/02 08:01 PM
CAZ Offline
Toyota Moderator
Yup, that has the 5M in it now. It "might" shortly be recieving a 6 or 7M. This engine is not too happy at the moment!
Here is a pic of this swap - after everything was nice and cleaned up!
<img src="http://home.4x4wire.com/caz/pictures/85%204runner/clean_5m_01.JPG" alt="" />
Re: vented rotor swap #31839 04/23/02 03:34 AM
Caz, questions.
! why is the swap picture of a yellow truck, and a black truck is sitting next to it. I think your pulling our legs.
The real question is what is in the Supra Jbox#2 that you have in there with the truck Jbox?
Paul Elbisser #3233
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6381 MB (Peak: 0.7604 MB) Data Comp: Off Server Time: 2026-11-16 08:41:41 UTC
