Lights #375848 01/08/04 12:32 AM
ok guys sorry no pics yet but I will try and get some soon. but my question. I have been looking at wiring diagrams for fog lights I have 6 lights on my bumper. Yes I know it sounds like overkill but it look good (2) 7" 100W, (2) 3.5" 55W white, (2) 3.5" 55W Amber (it gets foggy here sometimes. And it looks pretty basic as far the 55W with a bosch relay. But I found a few references that for the 100W to use a solenoid. It seems a lot for 2 lights but I don't know, what do you think? What are you using? All will be on separate circuits and should I worry about firing them up all at the same time? Well TIA GUYS.
ERick
Re: Lights #375849 01/08/04 02:47 AM
litnin Offline
I have two 130 Watt KC's on mine and they came with a standard BOSCH type relay. Been running like this for over a year and no problems yet. Not sure why they say use a solinoid. >??<
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: Lights #375850 01/08/04 03:55 AM
V
vovkus Offline
I have 2x130W ProComp and regular relay. No problems at all.
2001 Trooper LS 3" lift,no more Rancho 9000RX,
no more 4L30E transmission,
ProComp 8" 130W driving lights,
Surco roof rack (modified),
110V power outlet, Viair 380C compressor,
CB/FRS/GPRS/HF/VHF/UHF Radio, 285/75/16 BFG AT/KO.
Re: Lights #375851 01/08/04 04:03 AM
They're the same thing, but the solenoid is usually a little beefier. For what you're doing it'll be fine though, 100W is nothing. All they're saying is you want switched power (direct feed), not in series with one.
Re: Lights #375852 01/09/04 07:09 AM
ChulaVistaDave Offline
In Chula Vista, at the Auto Zone, you can buy the old style Ford starter solenoid for under $10.00. It is rated at 2400 watts. I run four (4) 100 watts and my high beams on for hours at a time with no problems. I did have a problem with the alternator, but that was from running on the beaches in Baja (salt water and alternators donÆt get along well)
See you out there,
Dave
91 Trooper. Mostly stock. Takes me where I want to go and brings me home when I'm done playing.
Re: Lights [Re: ChulaVistaDave] #375853 01/09/04 07:29 AM
StinkBug Offline
dude, my winch uses ford solenoids, I think thats a little overkill. I'm running 3 procomp 130s on the blazer and felt that one relay might not take the load, so i just put a relay on each one individually with one switch to fire all 3 relays. So far so good no problems at all.
For your setup i'd run 1 relay for each pair of little lights and one for each of the big ones. even that is probably relay overkill, but it would be safe.
Dallas
[color:"blue"]Crew Chief, RedBull RockCrawling Team [/color]
[color:"red"]StinkyFab Custom Metal Creations[/color]
Project StinkBug
Re: Lights [Re: StinkBug] #375854 01/09/04 09:13 AM
I have two 100w kc's and a regular relay. No problems yet, butI try not to run them for too long. (Makes the folks in front of me a bit edgy!))
Re: Lights #375855 01/09/04 04:50 PM
the load on 2 100 watt floods at 12v is 16.67 amps. As long as the relay is rated 20 amps or better you should have no problem.
Roy <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Lights #375856 01/09/04 04:56 PM
V
vovkus Offline
Best solution for the problem!
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6214 MB (Peak: 0.7070 MB) Data Comp: Off Server Time: 2026-06-17 11:28:29 UTC
