varying idle speed, new tach installed - questions #375865 01/08/04 12:50 AM
hubsj Offline OP
My idle (now monitored) goes up and down, not on its own.. if I give it gas, the idle remains high after the foot is removed. To get it back down, I have to give the pedal a quick tap and after the idle goes up, it goes back down to normal. I have checked the TB for gunk, and since it was recently cleaned, this doesnt seem to be the cause. Is it my TPS? any other ideas?
please help me out here.
88 4runner 22re 5spd 30x9.5 bfg AT
daily driver - weekly off roader.
284,400= Jasper - hello 5th gear!
true Thorley Header - V6 3rd
Valid inspection sticker (289,000)
Re: varying idle speed, new tach installed - questions [Re: hubsj] #375866 01/08/04 01:04 AM
jasonmt Offline
Sounds like mine when the dashpot on/under the TB was sticking. It didn't have enough force when letting off of the throttle to depress it, but blipping the throttle would.
Re: varying idle speed, new tach installed - questions [Re: jasonmt] #375867 01/08/04 02:06 AM
hubsj Offline OP
Thought about that too. It seems to be working ok, any good way to clean it if it is dirty? Although when i looked at it seems to be working correctly, dont know exactly what to look for, but it seems to work.
Re: varying idle speed, new tach installed - questions [Re: hubsj] #375868 01/08/04 02:27 AM
jasonmt Offline
I gave it a few cleanings but ended up just removing it. A good check is to wait until the truck is idleing slightly high, don't blip the throttle, open the hood and seem if you can close the butterfly any farther by hand at the TB.
Re: varying idle speed, new tach installed - questions [Re: jasonmt] #375869 01/08/04 02:34 AM
hubsj Offline OP
I think that might be the problem.
thanks
Re: varying idle speed, new tach installed - questions [Re: hubsj] #375870 01/08/04 11:27 PM
hubsj Offline OP
Disabled the dashpot, no change in problems. Still sticks at high idle. Anyone..
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6094 MB (Peak: 0.6784 MB) Data Comp: Off Server Time: 2026-06-17 13:09:22 UTC
