CJ7 Locking Hubs #377336 01/10/04 03:38 AM
mwhite Offline OP
I have a 83 CJ7. I would like to convert to the 6 bolt
pattern so I can use warn's premium hubs. Do I just
need to get the 6 bolt hub or do I need to change
hubs along with the backing plate to 6 bolt
Thanks Mike
88 Mighty Max 2.6 (170,000miles)
3 body lift, 1 1/2 torsion lift, lower bumpstops, 4.625
gears, 31 1/2 buckshot radials,warn 8274
Re: CJ7 Locking Hubs [Re: mwhite] #377337 01/11/04 07:40 AM
I'm not sure about your hubs, but if you do the front, how are you going to make the rear match? I know that late model SJ's are 6 lug D44 f/r. I don't know if you want to go full width though, or go through the expense of narrowing them just for new hubs.
Re: CJ7 Locking Hubs [Re: mwhite] #377338 01/11/04 11:21 AM
valleycat Offline
i'm confused, it doesn't seem worth it.
Re: CJ7 Locking Hubs [Re: mwhite] #377339 01/13/04 12:58 AM
mwhite Offline OP
I am talking about the manual hubs.
On 83 up they are 5 bolt and 82 on
down they are 6 bolt. I do not want to
change lug nut pattern only upgrade to
6 bolt locking hubs.
Re: CJ7 Locking Hubs [Re: mwhite] #377340 01/13/04 01:31 AM
What does Warn say about it ?
http://www.warn.com
Ask them directly. Nobody seems to know, including me, and this info could come in handy for others later.
Re: CJ7 Locking Hubs [Re: mwhite] #377341 01/13/04 03:19 PM
I've read that you can swap the whole outer knuckle from a dana 44 using chev/waggie brakes mated to ford f150 hubs, rotors and bearings. Do a google search if you're interested, or perhaps someone can fill in the blanks for us. Which spindle/stub shaft to use with a dana30?
<img src="/forums/images/graemlins/smile.gif" alt="" /> Just tossing out ideas. I've you're gonna spend money, you should get something stronger. A six bolt hub is marginally better than a five.
Re: CJ7 Locking Hubs [Re: mwhite] #377342 01/17/04 04:19 AM
The answer is yes, it is as simple as changing the hub. You'll have to use the inner bearing from your 5 bolt hub as the inner diameter for the spindle will not work if you use the 6 bolt inner bearing.
You can use Dana 44 stuff only if your caliper use the bracket with six studs holding it on. And using the Dana 44 stuff will require aftermarket inner axles which will accept the larger, 297x ujoint that the Dana 44 outer shafts take. Dana 30 outer shafts will not work with the 44 outers as the spline count is different along with the length.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6072 MB (Peak: 0.6843 MB) Data Comp: Off Server Time: 2026-11-16 01:32:16 UTC
