4th Genner's, look here... #377636 01/10/04 10:11 PM
azrain Offline OP
Tell me what you want out of a suspension kit.
Without letting too many cats out of the bag, I'd like to know what you would like to see in a performance oriented adjustable coil-over (all 4 corners) lift / suspension kit.
Thoughts and ideas ONLY, I will not say anymore than I have already.
Mike
Re: 4th Genner's, look here... [Re: azrain] #377637 01/11/04 07:46 AM
Jeff the marmot Offline
I obviously don't have a 4th gen, but I'd think a significant hurdle would be dealing with shocks for the X-Reas system, especially if you only replace 2 of the 4 shocks. I'd guess that would be a huge PITA just to figure out what to change if it can be changed. It would probably be quite a while before any aftermarket shock mfg'ers figure out longer shocks that can actually get incorporated into the X-Reas system.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
Re: 4th Genner's, look here... [Re: Jeff the marmot] #377638 01/11/04 09:14 AM
Robinhood150 Offline
FWIW, it's extremely difficult to get xreas here in Ca, unless one gets the sport model. I believe this also goes for NV and AZ. The dealer said we could order one from colorado if we wanted to pay $400 more for shipping.
How about cross linked shocks?
Steve
My Website ||Gettin' off 4wheel drive club member
'93 4Runner V6 4x4 auto tranny
If you have to ask about a SAS, you're not ready for it.
Re: 4th Genner's, look here... [Re: azrain] #377639 01/11/04 06:24 PM
Dandeman Offline
Toyota Moderator
I keep grinding in my head on ideas for a remotely controlled front roll bar disconnect..
Where you would essentially cut the roll (anti-sway) bar in the center, weld each side into a coupling/bearing to hold them in place, and remotely (air/electric) operated mechanism to lock the two sides together or let them operate independently.. And can't have hardly any tolerances or it's going to rattle..
All other disconnect ideas seem to be a pain...
Re: 4th Genner's, look here... [Re: Dandeman] #377640 01/11/04 07:45 PM
azrain Offline OP
XREAS won't work with what I'm scheming up, or it will have to be removed all together. Nor will it be cheap. There will be a number of custom components that I will have to design and build.
Sway bars, yeah, I've given that a great deal of thought as well. Circle track guys have some technology that may be adaptable... With the amount of on the shelf hardware that is out there for end links, etc. a shopping cart could be filled, you just have to know where to look. McMaster Carr, Grainger and a handful of local Industrial supply houses have more junk than I could shake a stick at.
I priced a brand new '04 at the dealer yesterday, SR5, center diff lock, some HD options, base everything else (base is pretty loaded), and a V8. $31,100.00 out the door, taxes and all. I'm thinking dual purpose wheeler / tow rig. The Tundra is nice, but I've gotten used to having an SUV.
I dunno, call it mid-life crisis if you will, but I need something to work on 'cause the 3rd Gen. is done.
Mike
Re: 4th Genner's, look here... [Re: azrain] #377641 01/15/04 11:06 PM
Good Times Offline
Front: Coilovers
Rear: Shock/Coil
The usual 3" of lift or more as long as the CV's don't go bad.
XREAS - eh just remove it if they have it smile
Other options that would be nice:
Swaybar disconnects
Some kind of Total Chaos/ATS Upper A-Arms
That should keep us busy for awhile!
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.012s) Memory: 0.6123 MB (Peak: 0.6992 MB) Data Comp: Off Server Time: 2026-11-18 21:49:32 UTC
