no clutch feedback #379519 01/13/04 06:58 PM
U
unirevolt Offline OP
Well, I was supposed to fix something else today; but I guess my clutch got jealous. Lucky me <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> There is no spring back to my clutch pedal. When I push on it goes all the way to the floor. I checked the spring, it's there. Any ideas?
Matt
Matt - 92 Rodeo LS (sorta)
tell tail signs
It's no fun to climb the ladder when the rungs on the ladder are bent - The Recipe
Re: no clutch feedback [Re: unirevolt] #379520 01/13/04 07:15 PM
F
Frisky Offline
Check the slave cylinder and the fluid level in the Master. The feedback comes from the pressure plate. Mine did the same thing when the slave went out.
1992 Isuzu Rodeo 2WD (some assembly required). "If it doesn't fit....Force it!! If it breaks, it needed to be replaced anyway."
Re: no clutch feedback [Re: Frisky] #379521 01/14/04 12:44 AM
Dude, I feel your pain. mine went out 2 weeks ago just before our New Years Day run. If fluid level is up you can try and bleed the slave cylinder to see if it somehow got air into the lines, if not, replace the slave cylinder first and then re-bleed, if not that, replace the Master cylinder. That's got to fix it as there is nothing more to the damn things. Be careful of aftermarket slave cylinders. I got mine at Autozone and it was defective. I had replaced both the slave and the master cylinders, bled the system and still no go. I then got an Isuzu Slave cylinder, replaced it, bled it out and whalaa, it works great. I hope it is not as cold where you are as it is in Utah, it hurts to breathe here. Good luck..
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5912 MB (Peak: 0.6460 MB) Data Comp: Off Server Time: 2026-06-07 02:23:06 UTC
