When I push the button to switch out of 4H to 2wd, there is a loud slamming sound. #380597 01/15/04 05:07 AM
TooEZgoin Offline OP
This has been happening on my 97 Limited ever since I installed the Revtek 3" coil over lift.
Does anyone know the source of the problem and the fix?
Re: When I push the button to switch out of 4H to 2wd, there is a loud slamming sound. [Re: TooEZgoin] #380598 01/15/04 05:12 AM
azrain Offline
While you are moving or sitting still? If moving, at what speed?
Mike
Re: When I push the button to switch out of 4H to 2wd, there is a loud slamming sound. [Re: azrain] #380599 01/15/04 08:00 AM
It happens at any speed when I push the button, from 5mph-35mph.
Re: When I push the button to switch out of 4H to 2wd, there is a loud slamming sound. [Re: TooEZgoin] #380600 01/15/04 02:56 PM
Maj Offline
If this is happening on dry pavement that is normal. If happening on dirt, I dunno.
1997 4Runner Limited 4x4, 'lectric locka
Re: When I push the button to switch out of 4H to 2wd, there is a loud slamming sound. [Re: TooEZgoin] #380601 01/15/04 03:38 PM
aowRS Offline
I sometimes get a moderate 'clunk' when disengaging 4WD - and mine is bone-stock. Try slipping the tranny into "N" right before you disengage. This may take some pressure off your drivetrain and allow the system to unlock easier.
Andreas
2001 4Runner SR5 4WD, Dorado Gold, 303,000+ miles
2014 Audi A4, Monsoon Gray
1995 Porsche 993, Polar Silver
Re: When I push the button to switch out of 4H to 2wd, there is a loud slamming sound. [Re: aowRS] #380602 01/16/04 05:10 AM
jataga Offline
Same here. Mine make a little metal clunking/engaging sound when I put it in and out of 4H.
Does it sound the same when you engage it?
99 Limited 4Runner 4WD
ARB front Bumper Kennesaw rear bumper
WARN 9500 Winch
Hella 4000s
Re: When I push the button to switch out of 4H to 2wd, there is a loud slamming sound. [Re: TooEZgoin] #380603 01/16/04 02:32 PM
Dandeman Offline
Toyota Moderator
The engaging/disengaging mechanism is a sliding, splined collar... both in the front axle ADD unit and inside the (at least the part time 4x4 drive) transfer case so any noise it makes is much like engaging/disengaging gears with no synchronizers... Not sure about the full time transfer case...
So it is totally dependent upon you to make sure there is no relative speed differences between the front and rear axles and therefore the recommendation to be driving in a straight line and if binding turning the steering wheel slightly to the right and left to unload any binding... and of course always have the exact same size tires between the front and rear....
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6176 MB (Peak: 0.6911 MB) Data Comp: Off Server Time: 2026-06-21 12:22:15 UTC
