2nd Gen Troopers-How Much Lift,Body Lift, Trimming, etc.. to get 35's under it. #381452 01/16/04 04:25 PM
TrooperMark Offline OP
Hey guys & gals,
I'm looking for some advice on what to expect trying to get 35's under my 1995 Trooper. The factory measurements on the tires are 34.99 inches, so they are diffinately big. I'm ok with a little bit of rubbing.
Thanks for the info.
Mark
1995 Trooper LS (OME Coils & 2" spacer, Rancho 9000, Nitto Terra Grappler 34", K&N, ARB Snorkel, Calmini Rear Bumper) In garage (9000 winch, custom S. America winch bumper, Delta Cams, Tera-Low 3.07)
Re: 2nd Gen Troopers-How Much Lift,Body Lift, Trimming, etc.. to get 35's under it. [Re: TrooperMark] #381453 01/16/04 06:29 PM
Smiley Offline
Mark...
Ya kinda just spoiled the surprise, huh?
Good luck! - Now I'm REALLY looking forward to seeing what you've been up to! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Cheers! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Smiley
Six Isuzus, so far... still have three of them.
Re: 2nd Gen Troopers-How Much Lift,Body Lift, Trimming, etc.. to get 35's under it. [Re: Smiley] #381454 01/16/04 07:33 PM
Smiley,
Well, I actually thought about setting up a new screen name so everyone didn't know but...then I would get the "welcome to the board...there is a search function...ect..." When I really was just hoping to get the facts. Even though the 35's surprise is out, there is still many more surprises to be seen <img src="/forums/images/graemlins/nana.gif" alt="" />.
Mark
Re: 2nd Gen Troopers-How Much Lift,Body Lift, Trimming, etc.. to get 35's under it. [Re: TrooperMark] #381455 01/16/04 07:37 PM
BigSwede Offline
I would consult Gilbert aka "trooperdude"...he has the most "built" IFS 2nd gen Trooper I can think of, though I don't think he has 35s.
Serenity now!
Re: 2nd Gen Troopers-How Much Lift,Body Lift, Trimming, etc.. to get 35's under it. [Re: BigSwede] #381456 01/16/04 07:44 PM
paulevans76 Offline
I remember seeing 2" suspension, 3" body, 15x8's w/ 2" bs for second gens to run 35x12.50
edit:
<<<<< also, see my avatar <img src="/forums/images/graemlins/pfft.gif" alt="" />
88 Troop - Posing yard art
Re: 2nd Gen Troopers-How Much Lift,Body Lift, Trimming, etc.. to get 35's under it. [Re: TrooperMark] #381457 01/16/04 08:00 PM
Smiley Offline
Hmmmmmmmmmmm... I'm guessing you won on a scratch-off lottery ticket or somethin'?
--- Greatà now IÆm gonna loose even more sleep, just wondering what you're up toà Thanks! <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/bird.gif" alt="" /> <img src="/forums/images/graemlins/pfft.gif" alt="" />
Just off the top of my head, I'll bet that a PM to ænhÆ might yield some answers.
HeÆs selling his 1993 RS w/ 35ö MTRs, but just looking at the photos of his rig, IÆm pretty sure he could tell you everything you wanna know.
Good luck and happy mod-ing! --- See ya in April! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Smiley
[EDIT]
^^^ Good one, Paul! <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: 2nd Gen Troopers-How Much Lift,Body Lift, Trimming, etc.. to get 35's under it. [Re: BigSwede] #381458 01/16/04 08:51 PM
Trooperdude Offline
In order to get my 35x12.5x15 to fit I have 3.5 suspension lift which consists of OME coils and 2" poly spacers and cranked up Sway-a-way 31.5mm torsion bars and a 3" body lift. I also had to cut the rear of the front fenders back about 2". I believe my backspacing on my rims is 4.25" You'll also have to limit your turning radius a bit because it will rub on the sway bars and bumper bracket.
Good luck
Gilbert
94 Trooper, 4 susp. lift, 3 body lift, 36" Swamper SX's , ARB lockers (front and rear),5.38 R&P's,Exo Cage, safari rack and ladder, snorkle, ARB bull bar w/ side bars,custom rear bumper, Warn 9000 lb winch and lots of other stuff.
Re: 2nd Gen Troopers-How Much Lift,Body Lift, Trimming, etc.. to get 35's under it. [Re: Trooperdude] #381459 01/17/04 07:34 AM
paulevans76 Offline
about my post up there
paging drakemore...
thats what he is running IIRC
and smiley, cant take credit, found it elsewhere, but it seems to fit my plans pretty good <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 2nd Gen Troopers-How Much Lift,Body Lift, Trimming, etc.. to get 35's under it. [Re: paulevans76] #381460 01/17/04 08:14 PM
edit:
Yeah that was my Recipe. I also have the 2" spacers. But I did my Math from what I thought were the masters the icelandic guys if you look at there wheelspacers that they are using it gives the ball park figure of 2" back spacing you still have to do some fender re-assignment (I was watching discovery it sounds intersting) I trimmed it back about 1-2" But I still need a little BFH work on the inside. I think that the Coils are a little soft so I plan on installing airbags for when I carry weight I rub on the turns. Well good luck.
Erick
P.S. Look for More power before you loose it, a clean exhaust, good air filter. Or else you will be forced to re-gear at where I am now I could wait it doesn't hurt me. powerwise.
Erick
Re: 2nd Gen Troopers-How Much Lift,Body Lift, Trimming, etc.. to get 35's under it. #381461 01/18/04 12:24 AM
Thanks Guys,
Just what I was figuring. However (Drake) the back spacing is quite more than I had put together on paper, I had figured aorund 3.5" to 4.5".
Guess it is time to place a call for parts.
Mark
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6396 MB (Peak: 0.7656 MB) Data Comp: Off Server Time: 2026-07-13 15:48:06 UTC
