Distributor on 3.0
#384914
01/22/04 02:22 AM
Someone suggested that maybe the rotor inside the distributor was bad on my truck, causing it to stumble. Anyone who knows, does it look fine? There are grooves on those little white things at the top of the cap and the metal end of the rotor does look a little rough.
Re: Distributor on 3.0
[Re: fpkelly]
#384915
01/22/04 02:39 AM
[Re: fpkelly]
#384916
01/22/04 02:48 AM
I see some scratches on the cap, usually caused by voltage. I'd replace both. my 2 cents. Go to Autozone.
94runner: Dana 44 SAS, 35's, Lockers, gears, winch, rock rails, bumpers, 3"BL, drivetrain lift, Budbuilt cross member, centerforce clutch and MORE! ***FOR SALE*** $8,500 -1985 Supra (STOCK!) FOR SALE $4,000 www.celicasupra.com
[Re: J94_4runner]
#384917
01/22/04 02:57 AM
Would this cause the engine to stumble? I was thinking the fuel pump but if I can manage to get the rpm's up around 2700 or higher it runs smoothly which led me to believe this might be the cause. This sound about right?
[Re: fpkelly]
#384918
01/22/04 03:01 AM
Hard to say for sure, but I did see some wear in the cap, and the end of the rotor looked dark, hard to be very specific in the picture, but for $30 (set) is better than ripping the fuel pump out and THEN realizing the Cap/rotor had to much wear. Those things are just a wear out item. 20-30K Item. If you run a MSD ignition box like i did on my Corvette, (msd 6AL) i was replacing cap and rotors every 12K.
[Re: fpkelly]
#384919
01/22/04 03:01 AM
just replace them, it will cause a stumble if its bad..its like $10 for a cap and rotor
#384920
01/22/04 03:08 AM
Im not worried about the cost, I just hate screwing around with it when its this cold here. Im trying to get it running fine again so I feel secure running up to a guy's shop to finish the driveshaft and some trimming of the brackets that I skipped while hurrying to finish the SAS. Almost forgot, how do I pop the middle thingy off? I pulled on it but it seemed pretty tight on there. I didn't want to pull too hard and screw something up.
